Question about Regina Dirt Magnet Hand Vac Belts
Replacing belt on a regina dirt magnet model DM1800
I need to replace the belt on my regina dirt magnet model DM1800, But I need instructions on how to take the vacuum apart to replace the belt.
3 Suggested Answers
SOURCE: bags and belts
hoover H bags work and Royal 4 &5reg. housekeeper belts work.Bought a piece of in. foam and cut it to fit my regina. Haven't found the hepa filter yet. I can't believe they just quit making these items!! Thanks for any help you have given me.
Posted on Aug 20, 2008
TEVA Guru
  • 65 Answers
SOURCE: replace the belt
I dont have an answer for tha specific model but most machines all have the same set up when it comes to belts, so please feel free to check this video out belt replacement.
hope this helps...
Posted on Sep 15, 2009
It runs but not pick up dirt in cup
Hello! If the dirt is not entering into the dirt cup this could mean there is a clog in the vacuum or a filter that needs to be cleaned or replaced. Check that the brushes are still spinning. The vacuum has a brush-roll shut-off pedal on the right side of the cleaner if you are standing behind it. Below are simple instructions for checking your vacuum for clogs.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
9. Inspect the belt for damages, if the belt is broken replace the belt with a Genuine Hoover belt part 562633001 Flat Belt Nano Upright
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Mar 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
I dont have a manual for the dirt devil vibe bagless cleaner. It's depositing dirt instead of picking it up. Is there a belt? i don't see one and maybe that's why
Information on your Dirt Devil Vibe Bagless Quick Vac M084500V can be found here:
http://www.dirtdevil.com/products/details.aspx?id=M084500V#parts
A link is available to download the manual as well as for replacement parts.
Yes this model has a belt to run the power brush; the manual has replacement instructions.
If dirst is being left behind it could also be a problem with a blockage, overfilled dirt cotnainer, or problem with the filter.
Mar 27, 2011 | Dirt Devil M084500V Vibe Quick Vac Bagless...
I need an owners manual for my regina steemer pro model: rg4152-1. it is a 7 amp cleaner. where can i find one?
Regina is now part of the Dirt Devil, your nearest dirt devil dealer should be able to assist you.
Oct 05, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Replace the belt
hope this helps...
Sep 15, 2009 | Regina ElectrikBroom RG100 Vacuum
Replacement of the belt instructions
should be just 2 screws by the beater brush, bottom front of the machine, pop them out and remove brush to remove hairs etc. put new belt in .
Jun 15, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt devil Model # 084590
It sounds like either the bearings are seized, or there is debris in the assembly. You will probably need to dismantle the vacuum and clean everything out. It's not unusual for vacuum s to get really dirty and need periodic maintenance. If you have replaced the belt, then you have the skill to do the rest. Note that after re-assembly don't try to lubricate the bearings. They will only collect dirt faster.
Apr 06, 2009 | Dirt Devil Featherlite Bagless Vacuum...
I have acquired an old Regina Electrik Broom
Hi jmathe, Looking at the back (business side) of the vacumn: Underneath the white plastic dirt cup, please find a cast aluminum latch, that secures the part you will empty. To remove the white plastic part, turn the aluminum latch handle downward, and to your right, while you are holding on to the dirt cup with your left hand. I usually wear a dust mask, and empty the dirt into a small grocery bag, to tie shut, before placing it in the trash. To replace the dirt cup, turn the cast aluminum handle back to where it was before, handle pointing left. The more often you empty the cup, the longer your Regina Electrik Broom will last. Mine is forty-five years old. Allow the motor to cool, often, as well.
Jan 07, 2009 | Regina ElectrikBroom RG100 Vacuum
Bags and belts
Aug 19, 2008 | Regina RG3100 Vacuum
Regina Dirt Magnet Hand Vac Belts Logo
Top Regina Vacuums Experts
JoeVacs
Are you a Regina Vacuum Expert? Answer questions, earn points and help others
