Question about Mattel Hot Wheels WALL TRACKS POWER TOWER TRACK SET
Hot wheels wall track motors not working
The lift system is not working
How small does your hot wheels car have to be to go on the hot wheels meg loop mayhem
I always bought the hot wheels cars that had race indicated along the side. Some of your regular hot wheels cars may still work but look for the ones that say race.
Jul 04, 2014 | Mattel Hot Wheels MEGA LOOP MAYHEM Track...
What causes an Error 2?
make sure no obstuctions at wheels or drivetrain if ok sounds like a weak drive motor you can take apart to see if pins came loose on axles to wheels
Jun 17, 2014 | Polaris 9400 Sport Pool Cleaner
Hot wheels sky jump track does not operate
TRY TO BUY A NEW ONE ,RETURN THE OLD ONE ,
-ANNA LEIGH MASON
Mar 21, 2013 | Mattel Hot Wheels Sky Jump Track Set
Am missing parts for Mattel Hot Wheels Criss Cross Crash Track. Need 6 curved track sections (Part number 2148-2050).
I don't have a solution to your problem with hot wheels but am wondering if you were Rosalie DeGraff 55 years ago when I knew you.
Nov 13, 2011 | Mattel Hot Wheels Criss Cross Crash Track...
How do I change the battery in a motorized wooden railway engin for thomas the train
2 options.
1.if its the kind that fits on the wooden track look for a screw (philips/star screwdriver) on the underside of Thomas near his face. The body shell should lift off.you will then see the battery.
2 If it's the plastic blue track you have to squeeze the right center wheel and left center wheel. Thomas has 6 wheels so the 2 center/middle wheels, after squeezing this will then make the top portion pop off.
Jan 10, 2011 | Thomas and Friends Battery Operated Train...
How to replace battery for Tomy Thomas engine, which has steam and sound, using blue plastic tracks? thanks
Take the screw out of the bottom front remove red plastic panel by lifting up on the front, this will allow you to lift front wheels up and to the rear, remove center wheels press the tabs on the left and right side in and remove the cab. One AA battery, reverse steps taken and begin playing.
Oct 18, 2009 | Tomy Thomas The Tank and Friends Track
I need to see a diagram on how to take apart and install a new wheel for pushing out the hot air to the outside.
Since you did not provide a make and model I cannot give you specific diagram or instructions. Here is the general procedure to replace a fan wheel that is attached to the shaft at one end of the motor.
Disconnect power. Remove drum drive belt from the small wheel at the motor. It should have a spring tension wheel that can be loosened to remove it. You shouldn ot have to remove the belt from around the drum. Remove the screws/bolts that hold the motor in place. Disconnect wiring if necessary. Keep track of what wire is connected to each terminal so you can reconnect easily. Lift the motor out and install the new fan wheel on the shaft (after removing the old wheel.) Reverse the procedure to re-install.
Jul 08, 2009 | Dryers
The passenger window came off the track. i need to remove the door panel and replace the window on the track/
My friend had 3 of 4 window lifts fail... the cable comes of the pullies and damages the plastic pully tracks. They're not repairable We bought new window lifts for iton the web. They're not too hard to replace. The aftermarket ones had crumby motors so we put the original motors off the broken lifts on. They've worked great since.
Jun 28, 2009 | 1998 Oldsmobile Intrigue
Mattel Hot Wheels WALL TRACKS POWER TOWER TRACK SET Logo
46 people viewed this question
Top Mattel Televison & Video Experts
Steve Mason
 Mikey
Mikey
Are you a Mattel Televison and Video Expert? Answer questions, earn points and help others
