Question about Regina Dirt Magnet Hand Vac Belts
How to replace the belt on a regina dirt magnet vac
I have a old regina hand held dirt magnet vacuum and need to replace the belt. How do I take the vacuum apart to do this?
2 Suggested Answers
TEVA Guru
  • 65 Answers
SOURCE: replace the belt
I dont have an answer for tha specific model but most machines all have the same set up when it comes to belts, so please feel free to check this video out belt replacement.
hope this helps...
Posted on Sep 15, 2009
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
How to replace handy zip belt ?
Hello! Below are step by step instructions to replacing the belt on your hand vac. I have also included a link to the instruction manual which has pictures as well as instructions. Really hope this helps!
1. Lift the black plug on the face of the cleaner.
NOTE: BLACK PLUG MUST BE ON WHEN ATTACHMENTS ARE NOT IN USE.
2. Use belt lifter.
3. Center and raise the Hand Vac with your left hand as shown. Using your right hand, dip the belt lifter in and hook the belt around the lip of the belt lifter. Slip the belt onto the motor shaft until the belt lifter base meets the shaft.
4. To insure proper belt placement, gently turn belt lifter counterclockwise and remove. Make sure belt is pushed back on shaft.
NOTE: THE BELT WILL COME OFF IF NOT PROPERLY INSTALLED.
6. To remove the belt, hold belt lifter. Hook the belt on the left side of the motor shaft, turn clockwise and pull the belt towards you to release.
http://pim.ttifc.net/document/1239/
Jun 26, 2014 | Dirt Devil Classic M08100 Bagged Handheld...
How to change belt on dirt devil handy zip
2. Use belt lifter.
Replacement hose for Regina Housekeeper Vacuum
if you have the broken hose you can go to a vac shop and thwey should be able to match the size
Feb 26, 2010 | Vacuums
I need an owners manual for my regina steemer pro model: rg4152-1. it is a 7 amp cleaner. where can i find one?
Regina is now part of the Dirt Devil, your nearest dirt devil dealer should be able to assist you.
Oct 05, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Replace the belt
hope this helps...
Sep 15, 2009 | Regina ElectrikBroom RG100 Vacuum
Kenmore vac producing burning odor
It sounds like you have bad carbon brushes on the motor. Get replacement brushes from a local vac shop, and take the unit apart. On each side of the motor their is a retangular piece of plastic with what looks like magnets in them. In most cases they are simply held by 2 screws. Replace these brushes and reasemble the unit. If the problem persists you have burned out the comutator on the motor and the whole thing must be replaced.
Apr 15, 2009 | Kenmore 22085 Bagged Canister Vacuum
I have acquired an old Regina Electrik Broom
Hi jmathe, Looking at the back (business side) of the vacumn: Underneath the white plastic dirt cup, please find a cast aluminum latch, that secures the part you will empty. To remove the white plastic part, turn the aluminum latch handle downward, and to your right, while you are holding on to the dirt cup with your left hand. I usually wear a dust mask, and empty the dirt into a small grocery bag, to tie shut, before placing it in the trash. To replace the dirt cup, turn the cast aluminum handle back to where it was before, handle pointing left. The more often you empty the cup, the longer your Regina Electrik Broom will last. Mine is forty-five years old. Allow the motor to cool, often, as well.
Jan 07, 2009 | Regina ElectrikBroom RG100 Vacuum
Dirt Devil Swivel Glide
look on the underside where the brush roller is and unplug it first then try to turn the brush roller by hand,if it turns real freely the belt is broke.you might have a clog at your intake hose at the bottom its the clear looking hose that goes from the bottom and comes up the back.if the belt is broke before you put a new one on clean the motor shaft there might be some old belt rubber on it ,otherwise the new belt won't last
Jan 03, 2009 | Dirt Devil Featherlight Bagless Upright...
Regina Dirt Magnet Hand Vac Belts Logo
46 people viewed this question
Top Regina Vacuums Experts
JoeVacs
Are you a Regina Vacuum Expert? Answer questions, earn points and help others
