Question about Delta Rp31558pb Classic Toe Operated Tub Drain, Pb
Delta tap drain leaks water down the drain when in the stop position
Water drains when in the stop position
    Problem Solver:
  • 12 Answers
Give me more info. I believe i can help
Posted on May 17, 2014
3 Suggested Answers
  • 67 Answers
SOURCE: drain doesn't work
theres a pop up assembly under the sink. The little clip on the rod may need adjustment to make the popper come up more or, theres hair ect clogging it just put in some Drain cleaner.
Posted on Sep 24, 2009
Dplumber
  • 119 Answers
SOURCE: my bath tub drain delta
You need a new stopper assembly. Call Delta Faucets and ask for a new stopper for free. They have been really easy to work with so far.
Posted on Sep 14, 2010
I have a silver Inesit WIDL 126 S washer dryer. Whenever the wash cycle completes, it then lets in some water from the inlet. Then stops. I tried draining it, it drains, then lets in water from the inlet,...
A device called a solenoid open and closes when activated by the control board (circuit controller). If debris collects inside of the chamber when it is open or closing, it can leak or simply shut down. This device will open upon command and allow water to enter or exit. It takes its orders from the command center and if it is damaged, plugged, or no longer capable of switiching on and off, it needs replacement.
Mar 12, 2014 | Indesit W 123 Front Load Washer
Water line will not drain
Double check the mains tap is fully off. If pos, open a tap below the leak height to let the excess water run off before it gets to the leak
Feb 01, 2014 | Plumbing
Toe tap drain leaks down the drain
sounds like the rubber seal is leaking replace the rubber washer
Dec 28, 2013 | Delta Rp31558pb Classic Toe Operated Tub...
F & S GWL15 would not drain. Replaced pump & it drained for a while. Removed diverter, found a dime & some lint, cleaned it out and installed it. Still would not drain, water is on floor, do not see leak....
Have you tried reverse flushing the drain hose?
If you can get the outlet/drain hose to the washtub cold tap
wrap a towel around the hose and tap to stop water going everywhere whilst slowly turning up the water pressure
from the tap.
(Any leaks STOP and check your hose clamps/connections are all tight.)
Water should now be flowing into the machine bowl, and
hopefully turned the pump, and cleared any blockages.
Hope it helps
Sep 15, 2013 | Fisher Paykel EcoSmart GWL15
How to drain radiator
hello. on the drivers side of radiator is a drain. here is a picture and the instructions for draining the coolant out.
  • Install a tube on the radiator drain. Place the end of the tube in the drain pan.
  • After the engine cools down, remove the radiator cap.
  • Completely open the radiator drain ****.
  • Allow the coolant to drain from the system until the flow stops.
  • Place a drain pan under the block drain hole plug.
  • Remove the drain hole plug from the engine block.
  • Allow the coolant to drain from the block until the flow stops. There may be more drainage from the radiator at this time.
  • Install the block drain hole plug.
  • Close the radiator drain ****.
    Jul 04, 2010 | 1997 GMC Suburban
    I have a Delta push down bathtub drain stop, but it is worn and does not stop the water. It does not unscrew as far as I can see how do I get it apart without removing the tube which I can not do?
    There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
    Lift and Turn:
    The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
    Toe Tap:
    The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
    If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
    This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
    Apr 06, 2010 | Delta T13420 Chrome Classic Single Handle...
    Hi my delta single hanlde tub/shower facuet is leaking hot water bad
    If its a ceramic cartridge type then replacing cartridge is called for, HOWEVER sometimes cheaper to replace complete tap.
    If not ceramic then turn mains off and replace the washer inside.
    Jan 08, 2010 | Delta Classic, Single Clear Knob Handle...
    How to fix a sulfur smell from hot water side of faucet.This started when we replaced an old faucet with a new one.
    Probably coincidence, but that sulfur smell is likely from your water heater.You'll either have to shut-off power, or gas, to water heater, and drain it down, then re-fill it, or leave hot taps on, and let it flush itself out. If you have a way of introducing bleach to line coming in to house, such as a pump or something , you can do that to help flush that smell out of water heater, otherwise, flushing or draining may be your only option.
    Jan 07, 2010 | Delta Victorian 2155-SSLHP Bar Two Handle...
    Faucet leaks above ball assembly when using cold water
    you have an 0-ring under the neck that has gone bad,you can replace this yourself if not a plumber can.
    Jul 21, 2009 | Delta Model 470: Signature Kitchen...
    Delta Rp31558pb Classic Toe Operated Tub Drain, Pb Logo
    Top Delta Plumbing Experts
    Donni Steen
    Ed Mac
    bwbconstruct
    Level 1 Expert
    Are you a Delta Plumbing Expert? Answer questions, earn points and help others
