Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Craftsman aircompressor bogging down
Motor running at half power I have a Craftsman Air Compressor, #921.153101 when it starts running it will get to about 40lbs of pressure and then will act as if it is bogging down and the motor really starts pulling. I had the capacitors checked and also took the motor to a rewind place and they all checked out fine, until you put it under load. I was wondering if it might be the check valve or pressure switch,or if its in the compressor part. any help is greatly appreciated
    Dedicated:
    Visited the website for 20 consecutive days.
  • Craftsman Expert
  • 242 Answers
Yes , the check valve will cause this. The check valve has a flat disk with a spring that holds it down that the air passing past it erodes away till it leaks then the air that the piston pushes into the tank does not stay in the tank but returns right back into the cylinder and puts a load on the piston. Also makes the compressor hard to start back up if it does get pumped up. Some have a dump valve that drains the pressure off the head after they shut off so it can start with no load. So if there is air bleading back and leaking at the pressure swith that will be a for sure sign it is the check valve.
Posted on May 20, 2009
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
My craftsman 3gal. compressor starts and run but no pressure is building up.it just keeps running and the gauge remains at 0 psi.
Is the petcock down below open or closed? If open, then screw it closed. Also, is the compressor portion connected to the motor working as it should? As the motor reciprocates, it should operate the compressor piston that pumps air pressure into the tank. Maybe something is broken there.
Nov 04, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My aircompressor is a little older and it is a 240 volt. Everytime I plug it in it turns on for about 10 seconds then shuts itself off. And then it won't turn back on until I unplug it. Outlet is...
This is usually a sign that the motor capacitor is bad.. and then it trips the overload...first thing to do is to replace the motor capacitor with a new one of identical rating...
heatman101
Sep 06, 2011 | Craftsman 33 gal Air Compressor 6 hp...
3 Gal, Craftsman Air Compressor. Builds pressure to about 20 psi, no further. While it was running, it bogged down and sounded different. I felt around the entire compressor for any leak, but only found...
It sounds to me like the motor is shot, Bogging down at 20psi makes me suspect the brushes are gone. No good contact on the brushes or even just a bad connection of the power cord will cause it to heat up and lose power under load. Check for worn or lose power connection first, then see if the motor brushes are replaceable. The brushes would be under a screw type cap on the motor with a spring holding the actual brush in contact. You will have more than one so give it good look over.
Mar 04, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
I have a Craftsman 3 gallon air compressor. When
Is your air pressure regulator set very low? Try adjusting it to a higher pressure
Mar 08, 2010 | Water Heaters
Bogs down after about 20 psi and stops running
there are a swhits adjustment under the black plastic.one nut and a screw. the lastic remows by one ore to screw. do not have the power on when doing this
Dec 04, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Have 12 gallon / 1HP Craftsman compressor, accidentally ran it while it was low on oil....about half way low. It shut itself off. Then, I added oil and it started up. But now it builds pressure VERY slowly...
Not the motor, but probably the compressor shot. Heat from friction (due to running without oil) probably scored the cylinder walls, which allows air to escape past the piston and rings, making the compressor VERY inefficient. Some compressors have replaceable cylinders... Not sure if the very small ones do or not.
Jun 26, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I started my craftsman 21hp 42in deck today it had a rough idle with backfire and when engade mower it seemed to not have enough power
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
It sounds more like the centrifugal switch in the motor (if it has one). In that case it's not running at half voltage -- it's only running with half its windings.
The switch would be on the shaft on the output end of the motor just inside the case. It could be sticking or it could have burned contacts, or it could be broken (it has springs in it).
The switch spreads as the RPM increases making and breaking contacts.
The run capacitor is probably okay, since a bad one would only keep it from running not starting.
May 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Compressor shuts off
Most compressors have a check valve installed in the tank that allows air from the compressor to enter the tank and not allow back pressure to the compressor. Also there is an unloader valve at the pressure switch that activates when the pressure switch cuts out releasing the pressure in the line. These two devices allow the compressor to start in an unloaded condition so that the motor will not strain. When you place you finger on the intake, the compressor is no longer pumping air thus there is not load on the motor. Your problem may be the intank check valve or the capacitor may be weak or bad. Simple check for both. Many volt meters have capacitor check and amp draw. The capacitor should not be more than 10 percent or rating. enjoy
Nov 28, 2008 | Craftsman Air Tools & Compressors
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
602 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
