Question about Uniden Radio Communications
Uniden UH710sx-NB will not transmitt
One receiver is receiving but will not transmit the room monitor is disabled
5 Suggested Answers
SOURCE: problem transmitting
hi there!
i bought the same pair of motorola, and i hav the exact same problem
i found out that they work good only when they are on the same channel but the sub channel must be set on 0.
for example channel 22 sub channel 0 .
Posted on Apr 28, 2008
eradiostore
  • 1654 Answers
SOURCE: Trouble transmitting & receiving on uhf.
While there might be a multitude of answers to this question. The first would be the radio is in need of repair, or not programmed correctly.
Posted on Jul 07, 2008
  • 320 Answers
SOURCE: Some bands OK some not. No transmit, no readout on some.
its the problem of the frequency range its getting blocked  at particular location.these can be solved by two options 1)first try changing the location of the unit from one corner to another corner.that should help to catch the frequency again if its getting blocked at particular location.this happens many times.but if changing the locan does not make any difference.then  2) get checked that the antenna of the unit is not catching the required frequency for the unit.so change the antenna also connect this external antenna  as mentioned 50 ω (it comes wioth SMA Connector) that helps in catchinf the frequency. you will get this at radio shack website. this will help. ----------------------------- also in the unit there is a component which controls the frequency called microprocessor if that goes weak the unit slowly slowly stops receving the accurate signals and only the noise comes.so the micro processor in located internally in the left side.its a green and black colour mini chip circuit board.many times opening the unit and removing and cleaning the microprocessor and refitting it solves the problem but this is 50 --- 50 chance. this all has to be checked what mentioned. thank you for using fixya.
Posted on Mar 31, 2009
eradiostore
  • 1654 Answers
SOURCE: Can Receive but not Transmit
1) Double check your interference code eliminator and the Qt filter. Make certain they are all set identical.
2) If you are still having trouble, shut off the Qt filter.
3) Then if you still have trouble shut off the code. (Off is sometimes "zero" or "n" for no.)
4) If the above steps do not help you have either a defective radio, or a bad battery. Switch the batteries out of the working units to the non-working and see if the problem switches to the other units. If so, replace the battery packs. (Note: it takes more battery power to transmit, so the problem would first show up in the transmit area.)
Best regards.
Posted on Nov 10, 2009
Testimonial: "Response from this site is almost immediate! Will try it out & respond asap ... although I must say I dont understand those techie terms:{ TQ anyway!"
I have a Uniden UHF CB Handheld Model # UH076SX-NB. Have had it for 3 years and only used a dozen times. Now I can receive but unable to transmit. Any solutions please?
How do you know that the radio does not transmit? The batteries need to be fully charged, or new to transmit. The radio is old, and the cost to repair it may be close to how much a new CB radio is.
Good luck.
Aug 25, 2016 | Uniden Radio Communications
How to disable the door chime
Remove the batteries or change the frequency of the transmitter so the receiver is on different channel or if you wish to jam it generate a frequency that will oppose the transmit frequency disabling it
Feb 13, 2016 | 2006 Kia Sedona
Tomy baby monitor not working
How exactly? Is it powered? Does it have no sound transmitting? Are both transmitter and receiver on the same channel setting? Are they close enough to be useful or too far away from each other that no signal is being received?
Let me know and I'll help further :-)
Oct 14, 2014 | Baby Gear
My uniden UH3O5sx is always stuck on receive (rx is always showing) can receive but not transmit
Set up your privacy tones or adjust the squelch level to stop the static and bring the handy out of receive mode. Some models have a busy channel lock out, that if it beleives it hears something it will not let you transmit over the other station.
Oct 04, 2014 | Uniden Radio Communications
I have a wavecom receiver model Rx 999 RF-Link a friend gave me I was wondering what it is for
The RX999 and the TX888 pair up to allow you to transmit audio/video signals from a device (like a TV) in one room to a receiving device in another room, without wires. Actually, they could both be in the same room!! My experience is that they work reasonably well, as long as the distance is not too great (I have had success up to about 100 feet) and there is no thick barrier between transmitter and receiver. For example, I wouldn't expect much success if one of the the two was in a steel/concrete bank vault. I have not used mine in about 17 years. I just dug them out and I am about to fire them up. Wish me luck.
Jul 24, 2014 | Audio Players & Recorders
My radio will not transmitt but it receives just fine
Most problems with radios that receive but do not transmit are antenna or antenna wire/connector issues. It's easy to receive with a marginal antenna but transmitting requires a good working antenna. If you have a SWR meter or can get your hands on one, install it in line with the antenna and test for reflected power. Of course, make sure your TX light comes on when you depress the mic switch. If not, switch mic and try again.
Hope this is helpful! Reply if u can.
Oct 06, 2012 | Uniden Solara DSC VHF Marine Radio
Uniden president ssb base no transmit and no receive how to fix
Have the mic checked first to make sure wired correctly and or wires not broken where connect to plug----also check to see if same on SSB and Am.
President what? Madison, Lincoln etc.
Apr 23, 2012 | Radio Communications
I am looking for a baby monitor with 2 transmitters and one receiver . i have not seen such a thing. i am willing to buy 2 baby monitors if either receiver will 'communicate' with either transmitter. ...
There are MANY products available that will suit your needs, begin your search HERE.
MORE
MORE
If more options are needed search your favorite search engine with the phrase:
"Multi Room Baby Monitor"
May 05, 2011 | Graco Direct Connect Monitor
Baby monoitor reciever piking up no sound or delayed sound - link light flashing
A delay may be caused by interference from other radio sources. I heard of one case where a woman's cell phone call overpowered the transmit power of her baby monitor.
Other things that can cause interference or other receiver problems:
1. monitor in contact or close proximity to running appliances or their cords. (induced electromagnetic field)
2. neighbor with baby monitor on same channel ('cross-talk')
3. distance between transmitter and receiver too far (the strength of a radio signal fall dramatically over larger distances. think of how often you lose cell phone coverage)
4. reduced power: low battery strength or cooked power supply
5. transmitter or receiver insulated from signal (if your monitor was transmitting/receiving through any metal obstruction)
May 07, 2009 | Kitchen Appliances - Others
No transmission
Bad transmitter, you might need to get a new set.
Jul 16, 2008 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Radio Communications Logo
56 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
