Question about Kenmore 43142 Front Load Washer
GE FRONT LOAD WASHER MODEL WBVH5300. STOPPED. CLOTHES WET. ERROR E43 DISPLAYED
jyackle5
  • 8197 Answers
SOURCE: error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Posted on Dec 18, 2008
  • 19 Answers
SOURCE: noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
Posted on Jan 25, 2009
  • 277 Answers
SOURCE: Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Mar 02, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Clothes come out super wet
Drive motor failure, CCU or Motor control failure. To ceck this look at your owners manual and from then test the parts with a multi meter. To keep from spending money you can unplug your machine for 15 to 30 minutes, plug it back in and sometimes that will clear the code and everything will work just fine. Also some parts are covered under the 5 year warranty so make sure about that also
Posted on Apr 17, 2009
canbruce75
  • 1776 Answers
SOURCE: My Kenmore Elite front load washer won't fill with
There are a couple of things that I would take a look at. The first is the water inlet valve. Disconnect the supply hoses and make sure that the small screens in the water inlet valve are clean and clear. Then test the solenoids for continuity using a multimeter. A lack of continuity indicates a faulty component. I am attaching a photo of the inlet valve solenoids for reference. If that is not the problem, I would next check the water level switch. This is diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As water level increases the pressure also increases on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to start the agitate cycle. Make sure the tube is not obstructed or damaged and the switch can be tested for continuity in the same manner as I previously described for the solenoids. Again, a lack of continuity indicates a faulty switch. Hope this helped and best wishes.
Posted on Aug 05, 2009
GE Washer Model ## WPSB9220D0WW Data Code31704 Error Code E43 Drive System Excessive Brake Time My washer don't do anything but show this error
On GE Washer Machines, E43 error code means "excessive brake time". The brake and speed sensor will need to be checked. You can try resetting the machine by disconnecting the power for 20-30 minutes. Keep in mind that your right model number is WPRB9220D0WW.
You can eliminate if it's the speed sensor by entering the service model. To do this:
- Turn off the washer at the power pad
- Remove power by unplugging the cord for 15 or more seconds
- Plug back in and within 30 seconds simultaneously press and hold the POWER and START pads for 3 seconds
- Should now display the model codes
- There are a bunch of tests but we are interested in the spin fast portion, so press the custom 2 pad until the display shows SF ( Spin Fast )
- Hit START pad... it should start spinning and display the rpm's
If it does this the speed sensor is working and the problem is the brake which means the transmission has to be replaced. Parts replacement can be find in THIS LINK.
If you do not feel able to resolve it, we recommend you call the technician to do it. Now you know what the problem.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 10, 2011 | GE Washing Machines
I have a GE Front Load Washing Machine, Model Number WBVH5300. When I turn it on to any cycle, the door locks, the basket turns to balance the load, the door unlocks, relocks and begins to drain. There...
Hello & Welcome to FixYa
If the drain hose is positioned correctly and the door lock assembly is fine then the problem is either the drain pump that is bad and needs replacement or the drain pump relay on the control board is bad and replacing the board will be recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 14, 2011 | General Electric WBVH5300KW Washer
Got an error message E43 model WPRB9220D0WW
E43 is for "excessive drive system brake time"
Reset with
1) unplug 3 seconds,
2) hold Power & Start to display "Jr",
3) cycle thru using the Custom 2 button (3 times) to display E43,
4) hold Power & Start to clear code to E00,
5) stop.
Jun 29, 2011 | GE Washing Machines
GE Aurora Front Load Washer leaves the clothes soaking wet
there is a filter under the washer door behind the panel...its white just unscrew it and clean out the filter and that should solve your problem.
Sep 18, 2009 | GE Washing Machines
Error code 3E Maytag washer
it overheated... turn it off, wait 10 minutes and take out some clothes
Aug 31, 2009 | Maytag MAH6500 Neptune Front Loading...
Can't see water level at all
Yes very normal in a front loader for clothes to be dripping wet but you may see little to no standing water.
Nov 02, 2017 | GE WBVH6240F Front Load Washer
Error code E43 on display of WPRB9220DCC GE Washer
This is the beginning of a leaking seal in the gear box. Some units have a pan to catch the leak from getting to floor. Seal needs to be replaced, otherwise gearbox will fail (lot more $$$$)
Jun 08, 2008 | GE WBXR3100B Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Kenmore 43142 Front Load Washer Logo
47 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
