When turned on camcorder gives off a buzzing sound and the picture shakes. At first, this was intermittent, however, 3 month later it is almost a constant problem rendering video unusable. In a local shop I was told that there is some sort of drive and the plastic casing maybe cracked. Any idea for repair? Greatly appreciate any advice-Milan Skarka
It can be the problem with video processing unit of your Camera. It can also be the casing issue. However for that you'll need to check what might be the case. If you have jewellers toolbox and have disassembled any camcoder before then you can check the camcoder yourself. Here is a link to free service manual for your Camcoder---
However, if you think you can't fix this yourself then i'll suggest you to get this done from a professional camera tech. If you want professional help then you can contact the nearest camera tech. Please see this link and see the camera tech available near your place--
The tape transport came up but now the unit will not "lock" the door to allow it to...
(More)
The tape transport came up but now the unit will not "lock" the door to allow it to retract. Everthing has worked fine in the past. I have NOT pushed the transport mechanism down as they warn you not to but because the pop open door will not stay closed there is no way for it to automatically lower as it is supposed to.
My HC7 started to roll on the flip out screen. I now can't use the touch screen or if I do get the...
(More)
My HC7 started to roll on the flip out screen. I now can't use the touch screen or if I do get the touch screen to function I can't see, due to the roll, where or what the touch panel is showing.
