Question about LuxPro PSP711TS Touch Screen Programmable Thermostat
Reset air psp511lca
Trying to reset the filter sign
    Problem Solver:
  • 12 Answers
To reset the air filter indicator:
1. Open up the control panel and turn the dial to "Air Filter"
2. Press the temperature up and down buttons simultaneously
3. Turn the dial back to "Run"
If you forget these instructions, you can find them in the owner's manual. You can download the manual here:
http://www.luxproproducts.com/pdfs/PSP511LCa_NL_ENG_Manual1.pdf
Posted on Nov 10, 2014
How do I deleate the change filter light?
My model is the psp511lca but it may be the same type of reset. I have a dial I turn to the "change filter" option and then press the up and down temperature buttons simultaneously and hold for a few seconds. When you turn the dial back to "run" the change filter light on the display is gone.
Sep 12, 2014 | LuxPro PSP711TS Touch Screen Programmable...
Lux TX500e thermostat
go to honeywell it,s a house hole name
Nov 07, 2013 | Lux Tx500 Series Smart Temp Electronic...
How to reset filter indicator on luxpro psp511lca
RESET FILTER COUNTEROnce you have replaced your filter, the filter life counter is reset back to its fullamount remaining value by turning the dial to AIR FILTER and pressing the UPand DOWN buttons together at the same time. NOTE: The counter is also reset bychanging the filter setting value, as described above, to a different number ofdays.
Jul 17, 2012 | LuxPro PSP711TS Touch Screen Programmable...
I have a Rheem Heat and air unit. Model # RGAC-080AW Serial # CM3D104 F4782 4794 and need to find out where the filter for the unit is located.
What filter are you talking about?
Air filter: Usually with a heat and air unit, the air filter is located behind the return air grill.
Return air grill looks similar to ordinary ceiling or floor grill where the hot or cold air blows into each room. Except the return air grill is larger and is usually put close to the heat-air unit.
Remove the grill and replace filter every 3-6 months.
If no filter is present, then dust and hair get stuck on the coils and unit will not meet temperature setting.
See image of typical air filter:
http://www.instablogsimages.com/images/2009/02/12/air-filter_IYR3W_69.jpg
Jul 30, 2011 | Rheem Water Heaters
Rheem air conditioner RHSL-HM3617JA how do I change the air filter
Air filter tray is integrated into the unit.
There is a door on the face at the bottom.
The door pops open and the filter slides out from the side.
The filter is MERV 8-13 depending, size 17.5x21x5 (17.25x20.75x4.38) It costs 30-70 dollars, but changing is very easy.
May 13, 2011 | Water Heaters
What is error code c2 11?
Clean the air filter even if it looks clean. The air filter is located in the front panel(unscrew knob to open door)...filter looked ok to me but cleaned it under water and that fixed the problem. Note: I cleaned the water filter first and that did not solve the problem. A simple test to see if the air filter is the problem...take the panel door off, press the filter door button and test hot water usage.
Sep 20, 2009 | Water Heaters
How do i reset my thermostat on my whirlpool gas water heater
On some models there is a thermal reset at the bottom to the right of the viewport, between two wires. The wires can either be two white and or one white and one black. It is a small white button. If it continues to trip you might want to check the air supply. Can check air supply by doing a draft test. And make sure the air filter at bottom of the heater is clean and free of any obstructions. Hope this helps.
Aug 31, 2009 | Whirlpool Water Heaters
Where do install a Heil furnace filter?
MAYBE IT DOES NEED IF THE FILTER IN THE COLD AIR RETURN GRILL MAKE SURE THEIR IS NO FILTER IN THIS FIRST , AS 2 FILTERS ARE NOT BETTER THAN ONE WHEN COME TO ELECTRIC FURN AND H/P ALSO IS THIS A UP-FLOW ,DOWN FLOW OR HORZ MEANING AIR #1 RTN IN BOTTOM DISCHARGE COMING OUT OF TOP OR#2 COLD AIR COMING IN TOP AND DISCHARGE OUT OF BOTTOM OR #3FURNACE LAYING SIDE-WAYS AIR COMING IN ONE END AND OUT OTHER THESE WOULD DETERMINE FILTER LOCATIONS
Nov 19, 2008 | Water Heaters
LuxPro PSP711TS Touch Screen Programmable Thermostat Logo
240 people viewed this question
Top Lux Water Heaters Experts
Gene Haynes
Bill
Level 1 Expert
Are you a Lux Water Heater Expert? Answer questions, earn points and help others
