Question about Ricoh Aficio CL3500N Laser Printer
How to reset a replace fusing belt unit error msg for ricoh mp c3502
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
Hi.
It needs to be replace the Fusing Belt or na expecifique Fuse (if the belt is still ok). Enyway you need to have knowledge and tecnical skils for do it. It is not a simple procedure ever for a high skill tec
Posted on Dec 29, 2016
SOURCE: Ricoh CL7200D Replace Fusing Unit (type C)
press the two arrow for 10 sec. hit enter you are in service mode
go to engine and diagnostic1 and sp7804 and go to 16
reset fuser change. enter
Posted on Dec 11, 2008
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
  • 86 Answers
SOURCE: Fuser Assembly Unit for RICOH Aficio MP 6500 Printer
This part number B2484582 is modified.
The new part number for the fusing unit is B2484583.
Yes, you can find it from a Ricoh Supplier.
Posted on Jan 21, 2009
  • 95 Answers
SOURCE: Error Msg ''reset Charger" on Ricoh CL5000
When you replaced the pcu you should have taken the 2 waste toner containers and the corona assembly out and put in the new unit. The charger unit is the part that has a telephone like plug on it.
Posted on Apr 23, 2009
  • 398 Answers
SOURCE: purchased new fusing unit for ricoh cl3500n;
You need to enter service mode, (this really should be done by a ricoh tech) Turn off printer press and hold down online and escape and turn printer on, the panel should sho a 1 2 3, push 2 for engine and enter press 7 and enter 804 is the counters for supplies. #4 is the fuser press enter after the printer says execute. Back out with escape and 3 to exit, cycle power. -Carl
Posted on Jul 08, 2009
Web Replacement error in ricoh mp 9001.
Clear modes(yellow) 1 0 7 hold clear/stop for 5 seconds, and reset the web counter. -Carl
Mar 06, 2015 | Ricoh Aficio Office Equipment & Supplies
Error cs548 in ricoh mp c4500
SC548
Fusing unit rotation error
The fusing belt sensor does not detect change in the actuator for 0.5
seconds after the fusing/paper exit motor has turned on.
* Defective fusing/paper exit motor
* Deformed actuator for the fusing belt sensor
* Defective fusing belt sensor
* Broken connection between IH inverter and IOB
* Incorrectly set fusing unit
1. Check if the fusing unit is correctly set.
2. Check or replace the actuator for fusing belt sensor.
3. Replace the fusing belt sensor.
4. Replace the IH inverter.
5. Check the connection between IH inverter and IOB.
Jul 14, 2014 | Gestetner DSm645 Digital Imaging System
How do I resolve knocking noise from fusing unit of MP C3502 Ricoh?
check movement transmitting gears, they can get broken or loosen ( a spring),otherwise you have to disassemble the entire fusion unit, again a bad gear and /or a broken belt. ( some fusions use fusion belts),if they get broken, they force the gears, make friction and noise.
Sorry, you really have to open the fusion unit.good luck! Ps - Plastics in this zone become very fragile and broke very easy! A broken piece of plastic inside fusion can make that, but this is just a supposition.
Mar 11, 2014 | Office Equipment & Supplies
Hy how are u.i hav a problem with ricoh mp c3501 copy machine.its showing error at screen SC582 if any body know about this error how to soulv it so plz help me am waiting.
Mr Aziz, the machine tell you the termistor had to be replaced located at the back of the fuser unit.After replaced it ,you have to reset the maschine in SP mode.....good day
Sep 01, 2013 | Ricoh Aficio MP C3501 Multifunction Color...
Apr 16, 2009 | Ricoh Aficio CL5000 Laser Printer
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Jun 05, 2008 | Ricoh Aficio CL7200D Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
2,281 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
