Question about Sony DVP-S725D DVD Player
Getting No Disk message on DVP-s725d
DVD Player has worked well. Now getting No Disk message when we put a DVD in player. Got this same message last year, then we recalibrated the machine - then it worked again. Trying to find the calibration coding again.
MYSTRO
  • 6 Answers
SOURCE: player won't play any disks only says CANNOT LOAD DISK
change the way you connect the dvd player to your tv
Posted on Jun 22, 2007
bluegreenash
  • 661 Answers
SOURCE: Sony DVP-FX810 Portable DVD Player, region code 4 to mutiregion code.
1. Switch on the player
2; open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
check with different region DVD
Posted on Oct 03, 2008
  • 3 Answers
SOURCE: unlock region code on Sony CD/DVD Player DVP-NS57P
I don't have a solution, but I know that the one about "press Display, Top Menu, Clear, Power" doesn't work.
Posted on Oct 12, 2008
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
Posted on Dec 21, 2008
SOURCE: my dvd working in good condition.but no video out
i have change setting and i can not seen video
Posted on Jan 06, 2011
My DVD got stuck in the five disk player. I took off the cover and removed the disk from the player and still get the e 27 00 message.
Hi, do a hard reset. Unplug from power, wait 10 seconds, plug back in and power up. That should clear the error message unless there is another disc in there somewhere.
Mar 01, 2011 | Sony DVP-NC600 Multi-disc DVD Player
Tip
Sony DVP-NS725P Region free code.
This region free hack also works for the DVP-NS725P using the original remote control. If the first one fail try the second one, it works like a charm.
Thanks a lot....
SONY DVP-NS300, DVP-NS305, DVP-NS400D, DVP-NS700, DVP-S330, DVP-S335, DVP-S360, DVP-S336, DVP-S525D, DVP-S530D, DVP-S535D, DVP-S536D, DVP-S725D, DVP-S735D
Multi-Region:
Turn On the unit with the remote controller
Wait until "no disc" appears in the unit's display
Press Pause, 3, 1, 4, 1, 5, 9
The word "CODE" should appear in the display
Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
Put the player into Standby mode
Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
Press Audio and Return for auto-switching On
Press Angle and Return for MacroVision On
Press Subtitle and Return for MacroVision Off
on Mar 07, 2010 | Televison & Video
Shows C13 error for dvd but plays vcd without problem
First play good quality lense cleaner dish ,if the problem presist power off then remove the top cover then press lense to mother board strip wire, or slightly clean it.If the problem will continue replace the lence.
Jul 31, 2010 | Sony DVP-S725D DVD Player
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
May 15, 2010 | Sony DVP-NS330 DVD Player
Instruction book required
Click HERE and check right side of that page to download required user manual of DVP-S725D
Thanks.
Apr 17, 2010 | Televison & Video
Hi had my sony dvp s725d from new 1999 and loved it, the problem is it switched off during playback, i thought it was a blown fuse but umpteen fuses later i came to the conclusion that it hadn't blown at...
First check the power supply after it has reduced the voltage and DC supply. That circuit is at fault & change it if available.......................sodeep
Sep 24, 2009 | Sony DVP-S725D DVD Player
Shuts down intermittently while watching DVD's
you may open your dvd casing and check with the capacitor next to the fuse this is busted you may notice that it deformed, remove and replace with the same specifications
Dec 19, 2007 | Sony DVP-S725D DVD Player
Sony DVP-S725D DVD Player Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
