SOURCE: STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
SOURCE: 2005 porsch cayenne s w/nav
Hi i like to know how to do front and rear breaks on a 2003 PORSCHE Cayenne s i know to know hwta has to come off the car and what size tools i would thanks robert
SOURCE: rear speakers stopped working
my speakers went out front and rear i was told by an audio tech. that the systems that chevrolet put in them each speaker has its own amp to bust the sound the only way to fix it is to replace them.
if you have a warranty chevrolet will replace them otherwise find a junk yard or new system. i ordered a set of used speakers off ebay havent installed yet.
SOURCE: I lost sound on one
first lets check
no need to open any thing
1) just trace the wire of working channel and plug out that and connect to opposite side of that channel
for example: if front left is not working, remove pin of front right and plug it into front left
after that listen the sound if front left is working then no need to open amplifier just check the wires of satellite speaker which is not working
how to check broken wire:
1) just observe your speaker nearly if you found any screw holes open it, if u can not find any screw holes remove front net which is fitted by press lock or any stepped groove, you can remove that and if you are removing front net you have to open speaker from casing then after you can find speaker's wire shouldered or bolted to it just check wire and go on after that u'll be sure that weather your speaker is failed or wire!!!
enjoy!!!!!!!!!!!!!!!
(don't forget to rate)
SOURCE: car speakers pop when on/off new stereo preamp out to Bose amp
Hi mate
this maybe caused by a positive and negitive wire touching somewere down the line!
just follow up your wires and check
