Question about Go Industries 27699 Chrome Knock Down Brush Guard GMC Sierra 1500 199
Truck wont start with key - Go Industries 27699 Chrome Knock Down Brush Guard GMC Sierra 1500 199
I have a 2007 odessey and i seperated the key from the key pad now van will turn over but wont start,i put keypad back on key but still wont start turns over but wont start any suggestions?
If you damaged a chip in the key, it won't start. You will have to get a replacement. You'll need the VIN# and go to the dealer to have one cut. Wouldn't hurt to take your key with you.
Feb 03, 2015 | 2007 Honda Odyssey
Lost my keys to my 2003 expedition my son took key switch out put a new one but anti theft wont let it start I found the old key how can I start it
You may be able to hold the original key close to the key lock and try starting the truck with a valet key that does not have a chip.
The sensor for the chip is close to the cylinder.
Sep 11, 2014 | Cars & Trucks
Wont start
it wont start you mean it dosnt turn over no battery left or it cranks but no start clean all the keys and you should have a master key like a green one or blue with a m on it put this key in the ignition turn on the ignition without starting then turn it off and repeat with the other keys you have as well make sure its in the park position and start it after you have finish with all the keys if wont crank over try in neutral position no start fuses battery starter and so on to check after
Apr 10, 2014 | 2002 Kia Sedona
06 equinox wont start.
Did you check the relay? Maybe swap it with another and see if that works.
Feb 06, 2014 | Chevrolet Equinox Cars & Trucks
A second key was cut at a lock smith but the vehicle will not start
if the key turns and finds the spring loaded start position, fully
then the key is good.
you failed to say,
wont crank
or wont start
to diametrically different systems.
if it wont crank , it can not start, short of being push started, with manually tranny , unstated transmission, makes my comments on the key line , useless.
Aug 22, 2013 | 2008 Suzuki Grand Vitara
I have an 89 f150 5.0 the key switch went bad so jumped silonoied and started right up. Put truck in gear then died. IV fixed key probably,but truck still wont start.replaced key cylinder, key switch...
New key has to be programmed to match computer in vehicle ! It takes 2 new keys and a programmer to accomplish this ! You will go crazy trying to chase it down , so just call a locksmith or someone witha programmer now before you damage something in the sustenta !
Mar 15, 2013 | Cars & Trucks
The security light on car wont start
You should try a different key if available. If no other key is available, you can try cleaning the chip embedded in the key
with a pencil eraser or give both the key and ingition a couple of short blasts of electrical contact cleaner.
Feb 01, 2013 | 1993 Buick LeSabre
Is reading theft system and wont start
Try cleaning your key off... those keys have security chips and if you get the oily or dirt on them your car wont start. Or try using a spare key if you have one... Good Luck!
Feb 17, 2010 | 1997 Cadillac Seville
Key is stuck in ignition and car wont start
When the battery is dead, the key cannot be removed. You can either charge the battery, and remove the key or, there is a access panel (small) under the steering column, remove this, and push a small pluger to the left, while holding the plunger, remove the key.
Dec 27, 2008 | 1997 Saturn SL
Go Industries 27699 Chrome Knock Down Brush Guard GMC Sierra 1500 199 Logo
268 people viewed this question
Top Go Industries Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Go Industries Hardware and Accessory Expert? Answer questions, earn points and help others
