Question about Insignia IS 20" TV040919 TV
Insignia NS-F27C 27" Flat Tube TV
The input keeps switching back and forth on this tv by itself and we can't get it to stop. If you hold down any button, either on the tv or the remote it will stop switching, but as soon as you let the button go, it starts to switch back and for again... what is going on?
  • 12 more comments
  • Anonymous Nov 21, 2007
    I am having an identical problem. The input keeps switching on its own.
  • getitfixed Nov 26, 2007
    I am having close to the same problem ..
    If i press any button on the remote it just switches to the next input.
    I cant access my cable channels, or any channels for that matter. It doesnt matter what button i press on the remote, it will just move to the next input option.
    I tried the buttons on the TV itself, they are inactive, except for the power button of course.
  • popnyah Nov 30, 2007
    Yeah, whats going on!!!! same thing happened to me. Whats up with this crappy Insignia TV's . front buttons are innactive and just switchs by itself.
  • fahadriz8 Dec 24, 2007
    Im having the same problem.
  • lfcedmonton Dec 25, 2007
    same problem - thought it was my 2 year old.  Very pleased I logged on. Hoping for a solution ASAP.
  • Anonymous Jan 13, 2008
    Mine is doing the same thing
  • Anonymous Mar 04, 2008
    no power
  • oleksa May 01, 2008
    I'm having the same problem.
  • bill47 May 05, 2008
    I've got the same problem with my NS-F27C. It has now migrated to the stage where the front panel keys (menu, ch+/-, etc) are not functioning, and the tuner i/p is skipped when changing the i/p on the remote. Also, no video or sound on any i/p, just the blue screen and text. Before I pay for a service manual, has anyone who has had this fixed (under warranty?) know whether the fix involed replacing any components, or was it a micro/memory re-programming exercise thru the remote/service codes?
    Thanks.
  • GUSS033 Dec 27, 2008
    ANY ONE SOLVE THIS PROBLEM YET, ANY IDEA, THANKS
  • Anonymous Jan 04, 2009
    on my insignia ns-f27c 27 inch tv the input keeps coming on when we press a button on the remote even when we dont it stil keeps going to input and the tv buttons dont work wats going on?
  • Anonymous Apr 11, 2009
    the explanations are very confusing...
  • mad_caroler May 11, 2010
    If anyone has a service manual or knows the steps to getting one.. please let me know
  • brokeandfix May 11, 2010
    I am having the same problem... but this is not a solution! Anybody have any luck with this one?
I repaired it!
My Insignia TV set started showing the same problem reported here, after a static discharge sparked when my wife was cleaning the TV with a cloth.
The information provided by bill47 proved to be very useful. I tried to find the data sheet of the large 64 pin IC, TDA973, I found the TDA 9351, which may be from the same family. I measured the voltage at pin 6 and it was approx. 0.2V. I imagined that if I forced that voltage to a higher value the IC would believe that no button is deppressed and so return to normality. From bill47 comments and my measurements of resistance to ground with the TVset off I estimated that a voltage divider was formed with a 3.3K resistor from +3.3V to pin 6 and 180 ohm to pin 6 to ground. In those conditions, I calculated that if I add a 18 ohm resistor from 3.3V to pin 6 I should force the voltage at that pin to 3V. I first tried with a 120 ohm resistor between pin 61 (peripherial power supply in) (+3.3V) and pin 6. This moved the voltage to 1.7V, the failure persisted, but the effect was different, as if another button, located at the rigth of the Input button, was permanently depressed. This showed me that I was in the right trak. I refined my calculations and replaced the 120 ohm resistor to 15 ohm. That raised the voltage at pin 6 to 2.5 V, and solved the problem. The front panel buttons were disabled (except for the Power button), but that is not a problem, I never use them, I always use the remote control. So I can continue enjoying my Insignia TV set! Thank you bill47 and all the other people who posted their comments.
Posted on Mar 30, 2009
  • Joe Astro Sep 25, 2010
    Great Post i have the same problem, BUT i don't understand if you jump 15 ohms resistor directly from pin 61 to pin 6 or add to 3.3k in series or parallel?
    Would appreciate any help.. really really helpful post....thanks
Purchased the service manual, and traced problem to the "KEY" input (pin 6) of the Philips universal TV processor chip (TDA9373 - the large 64 pin DIP on the main PCB). This single pin connects to all the front buttons/momentary switches making it extremely vulnerable to ESD strikes. Each of these switches is configured in a "resistor ladder" voltage divider circuit, which produces a unique voltage at pin 6 for each of the 7 switches. When no key is pressed the voltage on this pin should be around 3.3V (via 3.3K pullup to the 3.3V supply). My defective unit measures only 0.17 volts -- suggesting ESD damage. This condition confuses the processor (thinks a key is constantly being pressed) which explains the behaviour of constantly changing inputs, etc. In my case the front panel power button still operates because it shorts the input to ground (zero volts) which is still properly detected. Unfortunately the only remedy is to replace the part, which is likely fairly expensive. Because there is a microprossesor core in this device, it may have to be purchased directly from Insignia/Haier to ensure it is programmed correctly for the particular TV model. (Have not yet checked price/availability.)
Sorry for the bad news!
Posted on May 08, 2008
What is ESD? is that that I have to change?
any idea where can I buy it?
I was looking for Insignia/Haier but I didn't find something
thanks
Posted on Jul 07, 2008
So should i be assuming that it worked ?
Posted on Jan 23, 2008
Just sat on hold with tech support for over a half hour, someone finally came on and said this:
Unplug your TV, and disconnect everything you have attached to your tv (antennas, cable wire, input cables from VCR/DVD/cable box, EVERYTHING) and let it sit for about a half-hour to allow the tv to return to its factory settings. Then, plug it back in and see if it works.
It has not been the full half hour yet, but if I don't repost here, then assume that this solution works!
  • brokeandfix Jan 24, 2008
    Well, the above solution was a no-go for me.
    Called tech-support back and they informed me that I have to get in touch with the in-home service they offer and have a repair person come to my house and fix the tv. This is a free service since my TV is still under its 1 Year Warranty.
    so much for the easy fix-it-yourself answer, I guess!
    **If you are Canadian and purchased the TV from a FutureShop, you need to take the TV directly into the store and have their technicians deal with it. The in-home service that Insignia put me in contact with was at a BestBuy store, and they said that if they were to send someone to look at it, I would be charged initially and I would then have to submit the charges to the manufacturer to be reimbursed. It is easier to take the TV into the store and deal with the technicians there.**
Any one find any tricks that make it work?
Posted on Dec 25, 2007
I have a insignia ns-pdp50hd-09 plasma tv that has sound but no picture
You may try using the power switch on the TV itself instead of the remote. I have had trouble where the remote turn on doesn't work for the video, holding down on remote button longer seem to help.
Also you may want to try another input to the TV -so connect up input wires from your cable/sat to another one.
Jul 01, 2014 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
My Insignia NS-FTV27 (27") Flat
If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 13, 2017 | Insignia NS- 27" TV27 TV
The tv input keeps does not stay on the correct input eg. av1 even though it is the only device hooked up to the tv. After a short period of time it starts to scroll though the other inputs and stops on...
That tv input it is could be shorting out or it dying,if it is ramdomly switching to other inputs.Tries tv unplug,replug the tv back like about an hour later for the tv to a resetting itself.Go into the tv Menu go to PICTURES,go down to do a resetting to do a whole resetting of the tv Tuner signal board to go back to the factory setting,this problems should be solved.If not just used and connected other input ports connections on the tv.
May 13, 2011 | Insignia LCDTV26 26 in. Television
I need to know how to enter insignia ns-l42q-10a service mode. Thanks meetyahya
Did you try "Input , 2,5,8,0" ? May I know what exactly is the problem?
Caution:Be advised that the service menu is to be accessed only by trained professionals. Keep a notepad handy. If you accidentally change some setting then pen it down go back and change it again. Pen down the values of anything that you may wanna change. Be very careful.
Jul 08, 2010 | Insignia NS-L42Q-10A LCD TV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
27'' LCD panel compatability
Both power supplies are supplying the same voltages to the circuits but in order to use the one from the NS-27LCD 27" you will need to change the wiring configurations to make it work for the LCT2715..
I could repair the power supply from the LCT2715 for under $90.00 including parts, labor and shipping it back to you.
Let me know if you require further assistance.
Mar 01, 2009 | Televison & Video
Volume
Sounds like it's locked. Either hold the remote control "DISP" down for 3 seconds, or press it repeatedly about 10 times & it'll unlock.
Jul 16, 2008 | Insignia NS- 27" TV27 TV
Insignia Plasma 27" TV
i have the same problem... i think it happend when i accidently plugged left audio to white component on my dvd... HELP!!!!
Dec 24, 2007 | Insignia NS- 27" TV27 TV
Insignia 27", no picture, clicks on and off by itself
Had same problem with a 24" Insignia. Took it back to BestBuy who sent it in for repair. Repair ticket listed problem as a couple of "cold" solder joints. Apparently correct as set has worked fine ever since I get it back.
Nov 13, 2007 | Insignia NS- 27" TV27 TV
TV / DVD problem
did you try menu: video input 1 or front?.....
Oct 29, 2007 | Insignia NS- 27" TV27 TV
Insignia IS 20" TV040919 TV Logo
2,089 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
