Question about DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker
Delonghi Prima Donna - no water
Just plugged in our DeLonghi for the first time and when prompted to insert spout and hit ok, no water pumps through. The pump is running, but is loud and no water. Any hints greatly appreciated. Wayne
2 Suggested Answers
SOURCE: have a delonghi Prima Donna 6700 coffee machine and get this message
Hi there coffee person.
Have you tried disconnecting the machine from the power supply. As well as that check if there are enough coffee beans in the bean in the compartment and enough fresh water in the water tank. Not only this but is the compartment with the coffee "tablets" - full or empty. Fill or empty accordingly. Connect to power again, if the machine does not work the only advice have from here is "to clean the machine" as described in the manual or as you are used to.
Good luck
kolbrun
Posted on Mar 03, 2012
Cannot get steam to come out of my delonghi prima donna XS coffee machine
Could not find why but maybe if you go back over the scaling procedure and steam procedure there might be something you missed.
Please note! If "Energy saving" is active, you may have to wait a few seconds before hot water and steam are delivered.
Steam delivery 1. Make sure the hot water spout is attached correctly (fig. 7). 2. Fill a container with the liquid to be heated/frothed and immerse the spout/cappuccino maker (D5) in the liquid. 3. Press the steam ( ) button. After a few seconds, the steam to heat the liquid comes out of the cappuccino maker and "STEAM" is displayed. 4. When the required temperature is obtained, interrupt steam delivery by pressing the steam ( ) button again. (You should not discharge steam for more than 3 minutes at a time).
http://www.delonghi.com/Global/InstructionManuals/EN/EN-PrimaDonna-ETAM36365M-im.pdf
customer support
Customer Support
Nov 25, 2015 | DeLonghi Coffee Makers & Espresso Machines
How can I fix a very slow coffee cycle.
Maybe a very obvious question, but did you try descaling it?
Nov 15, 2015 | DeLonghi Prima Donna Avante ESAM6700...
Prima donna coffee machine hot water spout not working
does it get past the waiting part if not try resetting coffee maker by disconnecting from power point for 24hr the try unit again.
Sep 06, 2014 | DeLonghi Coffee Makers & Espresso Machines
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
Have a delonghi Prima Donna 6700 coffee machine and get this message
Good luck
kolbrun
Mar 03, 2012 | DeLonghi Prima Donna Avante ESAM6700...
Initial set up of delonghi ESAM6700 and it will not go past insert water spout stage. Even when spout inserted it does not recognise and we cant continue setting up the machine as it simply reads insert...
OK, I can answer this one... the same thing happened to me. It would not recognize the water spout. No beep when inserted, but it would beep if you inserted the milk container. Looking into the receptacle, I saw that the switch for the milk container is offset to the right, and the switch for the water spout is offset to the left. All I had to do was carefully bend the lower tang on the water spout that activates the switch to the left a little bit. It looked perfectly straight, but was just offset to the right enough to miss the switch.
Hope this helps someone.
May 08, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Hello We have a prima donna machine and
Check your programmed temperature setting; perhaps your machine has been set at low or medium.
Following are the instruction for Setting the Temperature from the manual for the ESAM6700.
1. Press the P button to enter the menu;
2. Press the < or > until "Set Temperature" is displayed;
3. Press the OK icon;
4. Turn < or > until the required temperature (high, medium, low) is displayed;
5. Press the OK icon to confirm (or the ESC icon to cancel the operation);
6. Press the button to exit the menu.
For a hotter coffee, before delivery rinse the appliance through by pressing the Rinse icon and confirming with the OK icon. Hot water
flows out of the coffee spouts and heats the internal circuit of the machine so that the coffee delivered will be hotter.
For an even hotter coffee, heat the cups by rinsing them with the hot water.
Mar 22, 2011 | DeLonghi Prima Donna Avante ESAM6700...
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Nov 19, 2010 | DeLonghi Prima Donna Avante ESAM6700...
No hot water coming out of the water spout - yet makes coffee ok.
There is a blockage in the milk/steam circuit. Most likely one of the solenoid valves or possibly the boiler. Would advise you take it to an expert repairer unless you are very handy with such things and have access to spare parts and cleaning chemicals.
Nov 14, 2010 | DeLonghi Prima Donna Avante ESAM6700...
DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker Logo
52 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
