Question about Bosch Refrigerators
The Bosch side by side freezer and fridge temprature is 4 degrees warmer than the set temprature
Kan62v00au
icansurf
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
  • 10865 Answers
SOURCE: Freezer not cold enough
Begin by turning the freezer temperature setting dial to a lower setting. Then wait a few hours to see if your problem is fixed. If that does not correct the problem you probably need to have the coolant system recharged. That requires special equipment so you will have to call in a repair person.
Posted on Feb 06, 2009
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
woodchuck789
  • 4070 Answers
SOURCE: Freezer is too cold (-14 degrees) and fridge is
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Posted on Sep 25, 2009
tzweeb
  • 318 Answers
SOURCE: Maytag side by side refrigerator - freezer side
you probably have a defrost problem. what you would see is frost on the rear panel of the freezer section at the back bottom.
this is common and you most likely need to replace the adaptive defrost control.
it is located inside the refr control box. you have to remove the cover and then the air housing with the lights attatched to it. once you have this housing down, then the "adc" is on the right rear and looks like a computer board.
dont try to figure out how it works, just replace it and then let the freezer warm up to remove the frost from the freezer coils. have a towel ready to pick up the excess water that will drip off the coil and onto the floor.it will take about 6 hours or so of being shut off.
after it has defrosted then turn the unit back on and with the new board it will start cooling properly again.
Posted on Jan 08, 2010
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
Fridge is freezing
There are two things you need to make sure before you declare the fridge at fault. Firstly, make sure that fridge isn't overloaded with items and that any air vents aren't blocked. Give it room to circulate the inside air. That helps it to cool evenly/at all. Next, find the thermostat. This will most likely be inside the top of the door frame when you open the door on newer fridges, or somewhere along the back or side walls. There'll be a setting for the freezer, and a setting for the fridge. The knob might use letters, numbers, or an arrow that says COLDER. Set the knob to slightly warmer, then leave the fridge alone for 24 hours. I highly suggest putting a suitable-type thermometer in the fridge and adjust the temp until it's around 34-38 degrees F. Do NOT allow the fridge to become warmer than 40 degrees. Between 40 and 140 degrees F is the "danger zone" where microbes thrive in food and are much more likely to cause food poisoning. You must never let food sit in the danger zone for more than 4 hours.
If cleaning the fridge and adjusting the thermostat don't work, you'll definitely want to have a refrigeration professional take a look at the fridge. It may as simple as adding coolant or "freon".
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
RS21DCNS
as a rule of thumb mfgs say give the unit 24 hrs to stablize where are you gettings the readings the fridge or freezer sides freezer readings run from -8 to -10 the fridge should run 34to38
Jan 31, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
