SOURCE: push the talk button and it said no link to base reconnect ac ada
go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
SOURCE: Says No Link...Reconnect base AC Adapter
Disconnect the AC adapter from the unit, wait for 5 seconds, then reconnect. The plug may have become loose over time or not be fully inserted. If that does not work, try re- registering the handset.
To re-register, see screenshots attached.
SOURCE: my phone wont work its fully charched but it keeps
Contact Panasonic Customer Support.If it is under warranty they will repair it for FREE.
SOURCE: "No link to base, reconnect
Disconnect the AC adaptor from the unit, wait for a minute, then reconnect. The plug may have become loose over time, or not fully inserted. If that does not work, try reregistering the handset, another handset may have deregistered this handset.Initially, the displayed message indicates that the base is not receiving power. Verify that the base is lighted up / powered on.Try a full hard reset on the Panasonic KX-TG9333T by disconnecting the power and telephone line connection to the base and remove the batteries of the 3 handsets. Allow unpowered, disconnected condition for an extended period of time (6-8 hours). The idea is to force the system to revert back to factory defaults.Reconnect the KX-TG9333T and the batteries to the handset. Recharge if necessary. Go through the initial set-up procedures.
SOURCE: My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
