Question about Timex Reef Gear 53572 wristwatch
Set time reefgear
Set time
How to set time on polar rs300x
Access watch settings scrolling by UP/Down button.
<Settings> <Ok> <Watch> <Time and Date Settings>
In Time Settings:
Set the local time (Time 1) and a time difference to it (Time 2).
With Time zone, you can select which time zone is used.
In Time view, you can easily change the time zone from Time 1 to Time 2 by pressing and holding DOWN.
Set the date with Date setting.
You can also download the user manual from the link below
http://www.polar.com/e_manuals/RS300X/Polar_RS300X_user_manual_English.pdf
Oct 06, 2015 | Polar RS300X Watch
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
How to set the time and analog time of CASIO ILLUMINATOR0 SGW 400 h
set the digital time: press and hold upper left button, then the seconds blinks use the lower left button to choose what are you going to set ( the one that blinks is the one that can be set ), use the upper right button to set. when your done. press the upper left button once.; set the analog time: from the time mode of the digital press mode until you see the "H.SET" , then the time of the digital appears, then use the upper right button to set the analog time, when your done just press the upper left button once and use the lower left button to bring back the time mode. i hope this will help you a lot.
Aug 13, 2011 | Watches
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
How to open a wrist watch
mcdevito75 here, Your Timex may have 4 small screws holding the back onto the watch, if so you"ll need jewelers screwdrivers available on ebay to open the back of your Timex, however this is rare with timex, look for a small tab or a cutout on the back cover that matched the same in the case, if you need to use a magnifier glass available at most Dollar stores or drugstores. Once you find this tab / cutout, use a steak knife under that tab or in that cutout and pry the back cover off the watch, Be firm with the prying but at the same time use care not to hurt your watch or hand.
Jul 27, 2010 | Timex 27191 Wristwatch
How do you set this watch....4 buttons
SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
Jul 26, 2010 | Fossil JR9455 Watch
My Times ReeFGear 50832 watch accidentally fell on the ground while wearing it and the outer ring of the watch is detached from the dial. Now since the plastic hook of the ring that attaches the ring to...
I suggest that you go to the Timex web site "timex.com" and click on "contact us" and you will see some addresses, phone numbers and email blank.
If you contact them, they should be able to help you.
Feb 16, 2010 | Timex 50832 Wrist Watch
Tipsy clock programming lost leaflet. would like to down load leaflet. bought this inexpensive clock at BB&B.
Hi I was having a hard time with this too, but luckily I found my leaflet.
To set time:
Press Mode 1 time
Press Set 2 times/ press up or down for hour
Press Set again for minute
Continue Pressing Set (up to 6 times) until everything is set
Back to normal mode- Press Mode 4 times
To toggle between 12 hr and 24 hr, press Mode 1 time
To Set an Alarm:
Press Mode 2 times
Press Set 1 times for hour, continue pressing set like you did for the clock.
Back to normal mode Press Mode 3 times
To cancel Alarm Press Mode 2 times and Set 5 times
Jan 16, 2010 | Watches
Cannot set the analog time on the Casio 2747.
In timekeeping mode press bottom left button 6x to enter setting mode.
Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
If you hold down bottom right, it will set time at a faster speed.
Hope this helps
May 25, 2009 | Casio AW80-7AV Wrist Watch
Timex Reef Gear 53572 wristwatch Logo
37 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
