Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Tranny locked up any sugestions
Transmission locked up, help
  • Anonymous May 21, 2009
    hydrostatic transaxle locked up, buy a new one is not an acceptable solution as the transaxle costs almost as much as a new tractor
  • 41 Answers
Go local lawnmower shop,find another and replace it. Save yourself time and money. (Transmission)
Posted on May 19, 2009
2000 chrysler cirrus comes up with 7oo code. Tranny won't shift from first gear.
Chrysler/Dodge,transmission computer's lock it into "Limp Mode", when it detects any transmisson problems. It will need scanned at a transmission repair garage Because the scanner diagnostic tool they use looks into transmission functions and errors, much deeper than a all purpose scanner tool. .Possibly an "Input" , "Output" speed sensor" or a bad solinoid pack. ( all 3 are external transmission parts.. These are very common to go bad and much cheaper than a complete, tranny rebuild.. But many rip off, tranny garages tell people that the transmission needs a complete rebuild.($1500. to $1800.) Watch out for this. It is possible that it needs rebuilt, but an honest tranny mechanic will let you know, either way.
Mar 05, 2014 | Chrysler Cirrus Cars & Trucks
Gear release lock on Cub Cadet GT1225
Does the unit function ( tranny ) normally otherwise? If not, then the tranny is locked. You have broken a gear tooth at a minimum in the tranny and it is locking the tranny gears.
Jul 05, 2013 | Garden
Transmission is apparently locked in 3rd gear. Gear shifter will not move.
unhook lincage at tranny and try shifting it unhocked if it shifts it inthe linckage someware cable or shift lever most likley linckage if it dont move at tranny its in the tranny
Apr 04, 2011 | 2000 Chrysler Concorde
Tranny drags in 2nd
More than likely your tranny is done. Time for a new one.
Best way to check is to take off the transmission oil cover on bottom of transmission. Check out the tranny oil and see if there if fine metal debris. Take a magnet and swish it around, if there is then time for a tranny.
May 10, 2010 | Jeep Cherokee Cars & Trucks
I have a 91 ford explorer 4.0 4x4 automatic transmission and when o put it in park it does not work, i have to use the e-brake to park the explorer...what part do i need to fix in the transmission that...
down at the transmission is an adjustment you can make to hopefully get it bak to park on the left side of the transmission you will find a cable with a nut at the end loosen the nut and move the lever on tranny until it locks into park. if it doesn't work get help from a tranny shop too complicated. and a major job to replace park pin
Jan 05, 2010 | 1991 Ford Explorer
How dangereous is to do a complete power flush in an automatic tranny in a 1990 civic if the oil is burnt
well oil is burnt! that *smells* up comeing trouble sometimes in your case this finishes the transmission off! people think this is good to do but unless you do it on a regualr service basis and manufactures sugested times you might finish it off! good luck to you my freind,John
Dec 22, 2009 | 1991 Honda Civic
2003 acura tl won't crank over.
Sounds like tranny froze up. Not what you wanted to hear, but the shop that put the tranny in should have given you a warranty. The lights came on, because the engine stalled. Please rate me if you find this helpful, thank you.
Jun 04, 2009 | 2003 Acura 3.2TL
Dodge cummins auto transmission
hello dodge cummins owner i myself have a 98 dodge ram 1500 5.9L truck and i just recently had to rebuild my transmission. my truck would go fine in reverse but would not move in forward. when i took the trany apart i found out that the clutchs were completely gone. but in order to rebuild your trany i would sugest in getting a shop repair manual. i had purchased a shift kit for 400 dollars and it came with all the clutchs that i needed and that is much cheaper than buying a tranny or even haveing a shop work on it. the shop wanted 1500 dollars to rebuild it and to buy a new tranny it was over 2000 dollars.
Jul 31, 2008 | 1991 Dodge B Series Cargo
Transmission leak!!
Had similar problem (Jetta 5 cylinder 2006) - leaks in the timing chain cover, large oil leak near the tranny (sounds like your problem), leak from "ALT belt side crank pulley seal and leak from oil pan. This car has only 23,000 kilometers about 14,000 miles on it!!! The dealer repaired this at no charge...
Signed
(waiting for the wheels to fall off...)
Jul 19, 2008 | 2006 Volkswagen Jetta
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
132 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
