Question about Whirlpool WTW4800XQ Washer
Washer jumps around during spin - Whirlpool WTW4800XQ Washer
2 Suggested Answers
huuum
  • 750 Answers
SOURCE: whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Posted on Oct 11, 2008
My washer is off balance during the spin cycle it jumps, and moves around
With the washer empty, tilt it front a few inches and drop it back down. This will re-level the legs. If it still jumps around, replace the drum snubber, inside the front of the machine. It's a rubber pad that keeps the drum from moving around too much. Snubbers dry out with age.
May 07, 2011 | LG WM-2277HW Front Load Washer
Washing mashine jumps around during the spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 25, 2011 | Kenmore Washing Machines
How do you keep washer from jumping around during spin cycle? The washer is on one of the Maytag storage stands. It is leveled on a concrete floor but jumps around when on medium or high spin cycle. Any...
first of all if this is a new washer you need to make sure all the shipping straps or bolts are off. one way to find out is to open the door reach and grab on to the tub it supposed to be able to move up down and side to side. if not then the shipping bolts has not been removed.
Nov 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Noise during spin cycle
I Can help
1: Unplug the Washer, turn off hot cold supply to Hoses.
2: Turn Washer around and remove Cover on Back.
3: Look at the "Belt" pull on it to see if it is Loose.
4: Check the "Pulleys" The "Belt" is connected to. Look for Signs of "Blackness" Caused by the Belt Wearing.
5: If thats the case just Replace the Belt.
Hope it helped
Please Rate Me
George
Apr 28, 2009 | Kenmore 43042 Front Load Washer
Jumps around
Mine did this, it never got fixed, repairman told me to replace it. I suggest you do the same. He told me the springs and bumpers had just worn out, and from the looks of my old washer, he was right lol
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool washing machine
Welcome hendrik,
washer cabinet.
normal.
Huuum
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Vibration
Is the machine level. The feet should be tightened and the nuts should be tightened against the cabinet. Tilt the machine back and check the shock absorbers. One of the shockies could have jumped out of the guides.
Oct 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WTW4800XQ Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
