Question about Fisher and Paykel GWL11 Top Load Washer
Inside tub is leaning against the side of the machine
Heard a loud noise like the machine makes when it is trying to ajust a load. The machine had just started washing and wasn't to spin yet opened the top and the tub inside was leaning againt the side of the machine. What happened and what do I do to fix it?
  • lori morris
    lori morris May 19, 2009
    O.M.G. i just had the same thing happen 2 hours ago. if anyone can help it would be great. have 2 kids and husband gotta wash 3 loads a day to keep it from piling up. thanks in advance.
  • jshepwnc May 20, 2009
    Interesting! same thing just happened to ours.
    Drum is leaning against the side of machine...
    now what to do?
    President:
  • 1,185 Answers
Your machine has snapped a suspension leg and needs and engineer
Posted on May 22, 2009
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
When in spin cycle machine made a loud noise then the spin cycle continued but very loudly. the machine would continue to wash clothes as normal and then get loud during the spin cycle again. at this point...
Hi if you can do it yourself, put the machine about 2ft away from the wall with the door faceing the wall,then lean it against the wall,this way you can look under the bottom off the machine,check to see if the drum moves from side to side,some times the shock absorbers come loose 1 at each side,all the best.
Jun 15, 2017 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
While finishing a load of laundry, during the final spin/rinse cycle the washer made an aweful pounding and banging noise. It was so loud I heard it from the other side of the house and went running to see...
Yes I do know unfortunely the basket support broke. This support is mounted on to the back of the basket and goes through the rear bearing and the back half of the outer tub. This is a very extensive repair .the unit has to be totally disassembled ,if it only broke the support it is about 100.00 , but if the rear tub bearing is also damaged you may consider replacing the unit with a new one either way this is an expensive and extensive repair...
Sep 17, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Noise from drum
This is difficult to work out as there are so many different symptoms. Here are my thoughts -
Dust from carbon rushes is black. Grey dust usually comes from a loose concrete weight. Loose tub weights are rare on this model but they cause a loud knocking noise which is often worse when the washing machine is revving up to spin and dying down from a spin (suspension problems are also often worse at this safe too). It's not normally a metallic sound though.
If the noise is coming from the motor banging against the sides of the machine then it will make the machine move when it happens. The whole machine may jump or move to one side. The motor often thumps the side of the washing machine on Hotpoint washers where the motor is fitted at the top of the tub and over to the right hand side. This is a daft place to fit a motor and only .I think they've eventually stopped now though.
It is normal to be able to push the drum to the side so that the motor hits the casing. If the suspension has gone, the tub should be twisted and leaning to one side more than the other or it just could be very loose. It's difficult to check suspension if you don't know how it should feel.
If the noise is coming from the inner drum hitting the heating element or throwing an object like a £1 coin (trapped between the inner drum and the outer tub) around, then the washing machine will be stable but the noise would still be a horrible metallic knocking. This is one cause I suspect.
Thank you for contacting Fixya.com
Aug 30, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
When washer agiates it makes a loud squeaking noise, what can it be?
Aug 30, 2009 | Washing Machines
Drum banging is it bearing when on spin
Aug 29, 2009 | Zanussi FLA1001W Front Load Washer
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
249 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
