Question about Panasonic PV-GS35 Mini DV Digital Camcorder
LCD Screen goes blank after opening up
The LCD screen flickers and goes blank when extended away from the camcorder.  The viewfinder works with the screen closed, and all other functions seem to work fine.  I am hoping that it may be easily fixed, as we like the unit.
  • 5 more comments
  • Patm1 Dec 09, 2007
    I am having the same problem with our Panasonic NV GS75 LCD screen.
    When i open it, it stays black but the viewfinder works. WHY WONT THEY BUILD THINGS TO LAST LIKE WHAT THEY DID 30 YEARS AGO?
  • wasteme Dec 15, 2007
    Similar problem. I open the LCD hinge and the screen freezes and stops working. It seems to work if the hinge is only 1/2 open.
  • craignkarin May 19, 2008
    I have exact;y the same problem - what's it cost to get repaired?
  • Misspelled99 Jun 08, 2008
    I had this same problem. It happened on the day I proposed to my girlfriend. I was hoping I could get someone to video it. I didn't realize that it still recorded till later. Grr...
    I checked one place and they said it'd be $144 to fix, then $15 for shipping. I'd LIKE to fix it myself, but I don't have such small screwdrivers.
  • streetball Dec 19, 2008
    i have the same problem
    it seems to work when it is only minimally opened or when it is turned so that the lcd is in a revers closed position (side viewing)
  • Anonymous Apr 30, 2009
    Mine has the same problem. And I barely used this DV. What a quality!!
  • Anonymous May 17, 2009
    When opening the screen it goes black but when I close it and it's about 1/4 way closed the lcd screen works. Camcorder is about 7 years old
I actually have several of these cameras and have seen this happen many times with this model. The ribbon cable that goes from the body to the LCD tears in the same place in all of my experiences. If you look at the hing area, you can see the black coating on the ribbon cable between the body and the LCD. The top edge of this cable tears right where it enters the LCD component. If it works when only 1/2 way open, it's just a matter of time before it totally stops working...the damage has already begun. A replacement LCD runs >$100. Instead, I search e-bay for parts cameras. Just make sure that the description doesn't say that the LCD is bad.
Taking apart the camera isn't all that hard. Start with the e-bay parts camera just in case something goes wrong. Take off the lens cover (the lens actually stays attached to the camera for this entire fix) by removing a screw on the bottom, one just under the eye piece, one inside the LCD door area (near the top), and one inside the tape area...the one closest to the front of the lens. Then, the lens cover slides forward. Once you get it moving forward, extend the eye piece and the lens cover comes right out.
The 2nd step is to remove the LCD. The easiest fix is to remove the entire left side (LCD and SD flip cover). This is done by removing the 3 screws on the bottom (careful, 1 is smaller than the other 2), the screw in the battery area, a screw near the front of the lens, and 2 screws near the top (one above and 1 below the lens). Once the left side is free, tip it forward, exposing the 2 ribbon cables. The larger one is the LCD. Disconnect it by simply flipping the grey bar where the ribbon cable connects to the body up. The ribbon cable should come out with no effort. The other, smaller ribbon cable is the speaker and the "LCD is Open/Closed switch". Be careful with this one. Hold the white connector in place against the body (I apply pressure using a small, flat screwdriver). Pull the ribbon cable out of the holder at the body with your fingers (it should require only a moderate amount of force). If the white cable connector comes off with the cable, you're in trouble...the wires are extremely thin and difficult to get back in the right place...but it can be done.
Once you've removed the left side portion, do the same with the good LCD. Reconnect everything in the reverse order. I use a small needle nose pliers to put the small ribbon cable back into the connector. The larger one just slides in with little to no effort. Lock it in place by tipping the locking back back down. Once you've connected these 2 cables, you can carefully put a battery in and test that it works. If all goes well, remove the battery before continuing to put it back together again.
When you're done, put the parts camera back together again and keep it. You may need it for the lens assembly (I've had grease inside my lenses at times and the front lens can scratch easily, so a replacement is good to have around).
I've tried replacing just the ribbon cable, but getting it out of the LCD isn't worth the effort since finding a good cable usually means that you've also found a good LCD for the above proceedure.
You can find the repair manual complete with exploded views at http://www.eserviceinfo.com/download.php?fileid=27179.
Posted on Mar 06, 2009
    Problem Solver:
  • 4 Answers
You will have to replace or get replaced the LCD hinge unit.The connector strip brakes after several intervals of opening and closing LCD Panel.
Posted on Oct 28, 2007
Use the above instructions, but if you can't find a parts camera as a donor, you can buy the right part for less that $20. The part you need is LSXY0763 and can be found on eBay or various internet parts vendors. I just fixed my camera with the instructions above. WHEN YOU TAKE OUT THE SCREWS, MARK DOWN WHERE THEY CAME FROM! The are all different sizes but look very similar.
Posted on May 12, 2009
Was able to fix my problem with guide posted by weatherguy00. Thanks you are awesome.
Posted on Dec 05, 2009
SOURCE:
When I look to the viewfinder I have a blank screen
Viewfinder, screen and pictures are blank / black - Nikon ...
https://www.ifixit.com/.../Viewfinder,+screen+and+pictures+are+bla...
iFixitMay 4, 2015 - When I look through the viewfinder or at the lcd it is blank / black. Also when I take a picture and view it on my computer, the picture is blank ...
SONY ' eSupport - There is no picture or a black screen ...
https://us.en.kb.sony.com/.../there-is-no-picture-or-a-black-screen-appear...
Dec 8, 2015 - There is no picture or a black screen appears in the viewfinder or LCDwhen attempting to ... Look to see if an image can be seen in the viewfinder or LCD. IMPORTANT: Some camcorders have both a viewfinder and LCD.
There is no picture or a black screen appears in the ...
Jan 11, 2016 | Cameras
Sony DCR-TRV250E.
was the problem the lense cap, or you do still need assistance?
Mar 28, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
Not able to view anything on screen
I work on this model of samsung the lcd problem is a common thing with this camera
The ribbon cable to the lcd from the camera cracks and causes what you are talking about .
Normally the camera will still work buy using the eye viewfinder for recording and playback but you will not hear the sound unless the lcd door is open but then the picture in the viewfinder goes away when this door is open and comes back when it is closed
my email is spinboss@comcast.net and sell on ebay as uromastyx
Jan 25, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
LCD Screen wont show anything but still usable..
There is connecting flexible cable/ wire between lcd board and camcorder board which is cracked and requires replacement.
I can provide you part number of flexible cable and rest is your own skills like how to apart camcorder and lcd section.
If you are familiar with camera repair, let me know to proceed.
Jan 06, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
HANDY CAM LCD SCREEN BLANK
Inside the door hinge area is a small switch that normally would turn off the viewfinder and turn on the LCD panel. THat switch could be defective or mechanically not being switched. WIthout opening up the unit, I can not tell specifically. This shouldbe a simple repair for any shop that repairs cameras.
Dan
Oct 06, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Records audio but no video
Replace the ccd base assumbly and check.
Jan 01, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
LCD Display Screen
There is something wrong with the flex and it needs to be replaced this happens alot on this model at work sorry
Dec 24, 2007 | Canon DC100 DVD Camcorder
Camcorder LCD screen only operates up to 30 degrees from camera
open the unit. find the flat flexible connector to the LCD and then look at each end to verify if fully inserted into its mating connector.
May 30, 2007 | Panasonic NV-GS15 Mini DV Digital...
Open Questions:
Panasonic PV-GS35 Mini DV Digital Camcorder Logo
919 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
