Question about Sewing Machines
How to wind bobbin juki ddl-550n-7 - Sewing Machines
yalmer
  • 552 Answers
SOURCE: threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
Posted on Apr 02, 2008
  • 13 Answers
SOURCE: juki ddl-227 industrial machine
Before all else. Turn off machine!
(1) break screws on the hook loose.
(2) tighten one back up very skightly, one you can reach when the needle bar is at its lowest position.
(3) lower needle bar to its lowest position.
(4) loosen the screw just tightened.
(5) position the tip of the hook behind the needle hole. the tip should be as close to the needle hole as possible without actually touching the needle
(6) tighten screws
(7) slowly hand turn the machine (depress the foot pedal to disengage clutch brake on motor) several revolutions to make sure the needle doesn't hit anything on the hook.
(8) if it passes this test, try on a scrap of fabric
Posted on Dec 15, 2008
SOURCE: Filling the bobbin with my Juki DDL-5550-6
It's actually designed that way on purpose so you can wind a bobbin while sewing. If you lift the presser foot, at least it'll make less noise in the process.
Posted on Apr 16, 2009
SOURCE: i need instruction and parts manual for juki
JUKI HOME SEWING DIVISION
8500 NW 17 th Street
Miami, FL 33126
Phone: (305) 594-0059
Posted on Jun 03, 2009
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
Posted on Aug 20, 2009
Manual needed for juki ddl 555 also need bobbins for this machine
go to the Juki website and ask them about a manual and bobbins
Mar 15, 2015 | Juki Sewing Machines
Juki DDL-8500 bobbin stopped working, wheel slid over and rests against reverse bar.
Hi there
please check the silver wheel by hand move or stuck? if stuck please drop some gas or and cleaner inside it and move by hand until it be free.
regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Dec 16, 2013 | Juki Sewing Machines
Oily bobbin
Sounds like you've over oiled your machine. Take the bobbin out, strip the thread from it. wipe it down well... and re-wind the bobbin with new thread.
Next time you oil after your day of sewing. Place a piece of absorbent scrap fabric under the presser foot to catch excess drips.
Sep 27, 2013 | Juki DDL-8700
Juki DDL8700 Bobbin Winder Problem
the machine should be checked by a sewing machine technican
to see what wrong with the bobbin winder, the assembly may need
to be replaced
Dec 20, 2012 | Juki DDL-8700
Activate juki ddl-8700-7 bobbin counter
good luck i have 12 juki auto machine and no one can figure that out!!! that panel on top should be shot.
Jul 28, 2012 | Juki DDL-8700
My bobbin stitch is too tight on my Juki DDL 8500-7, how can I fix this?
Hi LJ,
Look on the bobbin case, and see if there is a small screw. Usually that is the tension of the bobbin. You can adjust that until there is only slight tension on the bobbin thread.
Hope this helps
Joe
Sep 17, 2011 | Juki DDL-8300
I just received my Juki 8700. I new to industrial machines. How do I wind the thread onto the bobbin?
There should be a bobbin winding device next too and slighlty behind the drive belt.
Should be like this bobbin winder.
Mar 11, 2011 | Juki DDL-8700
I just bought a used juki DDL 8500 industrial sewing machine. It didn't come with manual. I also can't find a bobbin casing. I feel very foolish. There appears to have a bobbin winder on the side....
I just bought the same machine and mine came with a photocopied manual. There is indeed a bobbin winder on the side, there's a flat section on the side of the bobbin winder closest to you, if you push that forward it connects a wheel attached to a bobbin spoke, to the belt that runs between the machine and the motor. To wind the bobbin, put the bobbin on sideways onto the axis of the wheel that is on the inside of the machine, and push the bobbin winder forward.
If you're looking for where the bobbin case is located on the machine, if you look underneath the machine on the left hand side, there should be a metal belly, on the left side of the belly is an opening, and in there sits the bobbin casing.
I think you were asking for either one of these answers, I'm on here troubleshooting for my Juki DDL-8500, good luck with yours, hopefully I can find what I need to know too!
Feb 07, 2010 | Juki DDL-8300
Feb 25, 2009 | Juki DDL-8300
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
