Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a Husqvarna 345e chainsaw. Can't get the cover back on.
I have a Husqvarna 345e chainsaw. I took the cover off to replace the chain, but now can't get the cover back on. The brake won't go back over the clutch drum for the kick back brake. I don't know how to get it to go back on. Please help.
  • Sold154 May 19, 2009
    Same exact thing with my 235 only 2 weeks old
That metal band you see which is preventing you from putting on the cover is part of the chain break mechanism. You were suppose to disengage the break before taking off the cover (I did the same thing). To get it back together you need to disengage the break by a tricky procedure and that will make the band diameter larger so it fits over the clutch. To force the band open, you need to first place the cover over the two bolts that hold the bar. As you already know, the back of the cover will not be able to fit over the clutch. Now in this angled position, bend (force) the break lever down (gray thing on top) until you can force together the sproket in the cover onto the mating pastic fitting built into the break lever. Now you can use the break lever to force down the internal spring and open the metal band. That will expand the stainless steel band and it will fit around the clutch. If you now push down on the back of the cover it will snap in over the clutch. Once you see how it is done, it is not so hard, but it is tricky because you are forcing some of the parts slightly out of position to get it back together. .
Posted on Sep 19, 2010
  • Eric
    Eric Dec 29, 2014
    It was tricky but after reading this I was able to get my Husqvarna 445 back together &running. Just a note also the bolt that holds cover can come loose & it actually allows the oil to drain. The bolt is inserted through the chain oil
  • 4 Answers
Okidoke, flip the cover over. The chain break spring is under a plastic cover with 3 screws... do not remove this. See the metal break mechanism that goes into the break handle? Get ahold of that with a pair of plyers, have someone hold the plastic cover, now twist the mechanism into place. It will take some force, and do not get ahold of the plasitc with plyers, it will break. Also, you could make a wrench just for this. Take the spark plug wrench and cut it to fit over the above mentioned break "switch", then use that to turn it. Easier to show you, if you have questions, or this doesnt make sense, email me and I can get you some pictures. I have a Husqvarna 235 that had this same thing.
nflcowboys1970@hotmail.com
Clint
Posted on May 23, 2009
The chain brake spring is set to "on", which is why you can't slide the cover back on. Fit the cover back on enough to throw the brake bar- with an audible click. Make sure you leave it in the "off" position- then the spring will be in the open position and the cover will slip right on. I got this from the manual when I finally figured out where to look.
Posted on Jul 14, 2010
Having this issue as well - however the lock will not disengage, the band will not widen. Half installing the cover and trying to disengage lock is only damaging the corners of the grey plastic.
Posted on May 11, 2015
I don't know what to say since a mechanical person like my son might take a chance and retool the piece. I think you're talking about the 3 pronged part that fits into the brake with a spring that works on inertia or force. I didn't try that. But what I now learned is the brake, that circular metal piece in the clutch cover of my 235e wouldn't fit around the circular part with the clean springs in it. Anyway if you're an expert you might know what I'm talking about. I took it to Tractor Supply and in 45 minutes two people there were able to get it back on, but as soon as they removed it they were stuck again. I think the hand brake for safety never worked properly. I got my money back. I went to HD to look at another out of curiosity and moved the emergency brake for kickback and found it didn't click in or out like any model regardless of price. The Echo did, the Homelite did. Even my old Sears did. I think there's a problem with the 235e.
Posted on Aug 02, 2009
Call the manufacturer and order a whole new cover for around $60 bolt in place and go. Or as my southern friends say plug and play yaall.
Posted on May 13, 2011
Install side cover on 455 rancher with chain break
Problem is you removed side cover with chain brake closed. You must open the chain brake to re-install the cover. You can do it with the handle. Put the side cover into position, put the handle into the fitting on the side cover. push the handle forward until you feel the "3" point connector engage. apply pressure to the handle and pull back until the side chain brake "Pops" open. Your Husqvarna dealer has a tool to open the chain brake if you are unable to get it open. Takes about 5 mins.
Feb 10, 2014 | Husqvarna Garden
How do you set the chain tension on a 345e?
The E version is tooless, so flip out the wing in the centre of the big cover fixing nut,slacken the nut off half a turn, now turn the knurled adjuster in the side cover, down to tighten, up to slacken, there are many schools of thought about the correct tention of the chain, but basically the chain should sit snuggly all round the guide bar, and with a gloved hand pull manually around the bar with out too much force, it should never sag on the bottom of the guide bar.
Apr 27, 2011 | Husqvarna Chain Saw 20" Bar
I have a relatively new 16" Husqvarna chainsaw, and I have the hardest time getting it started....sometimes I can't even get it started. Once I get it going, it usually runs fine, but it is extremely...
We have a Husky 435 (two year warranty) that was new last year. It would start and run fine for several days, then nothing--took to warranty service where they replaced the ignition module the first time. Ran for several more days, then nothing again--this time they replaced the carburetor and it seems to working fine from then on. Suspect that Husqvarna has had problems with our ethanol-blended fuels. If you still have warranty coverage, then take advantage. Hope this helps!
Jul 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 345e
I have a model 435 Husky that had the same hard-to-start problem--warranty service replaced the carburetor and it seems to work ok now. The chain that continues to turn can be fixed by turning the idle-speed screw (not the H or L jet screws) CCW a small amount until it can be accelerated then dropped back to idle to quit driving the chain. Hope this helps!
Apr 05, 2010 | Husqvarna 450 e-series 18" Chain Saw
I need to replace the chain sproket on my Hsuqvarna 345e chain sa
It has an out board clutch, please view this it is essentially the same.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
    Let us know how it worked for you.
IPL and operator's manual download
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
You may find detail B beneficial. HTH
Lou
Dec 17, 2009 | Husqvarna Forest & Garden No.967012396 345...
Hi, I took off the clutch cover for my Husqvarna 136 saw and I can't get it to go back on. Any suggestions?
you need to disangage you chain brake band as it is engaged and wont go over the the clutch hub sprocket
Aug 05, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
18" husqvarna chainsaw
It sounds like your chainbrake was on when you took off side cover .To get brake off place cover against saw with bar off so cover fits into brake lever and pull back on lever
Oct 14, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
4,752 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
