Question about Freezers
Imperial freezer manual - Freezers
Imperial heavy duty freezer is not freezing. Exterior very warm
You need a refrigeration engineer. It sounds like it needs refrigerant gas. Worst case scenario is that the compressor has failed. Both low gas and a failed compressor generate heat.
Jun 12, 2016 | Freezers
Freezer temp keeps dropping despite putting on superfreeze switch. What might the problem be?
I own an Imperial freezer and it has a superfreeze switch. The schematic electrical diagram on my freezer shows that the superfreeze switch when activated, bypasses the temperature control thermostat and keeps operating the compressor motor non stop. Try switching the superfreeze to off after you reach your desired freezer temperature.
Aug 28, 2011 | Miele 4.2 cu. ft. / 119 liter Upright...
I have whirlpool imperial series refrigerator model et1lfkxkq03, which has freezer on top. Water from freezer is leaking into refrigerator. I cleared out the freezer and can't find the clogged drain.
You will probably have to remove the back panel, which is the evaporator cover. The defrost water drain is always at the base of the coil. **** the drain out and pour some hot water down it
Jun 22, 2011 | Whirlpool Freezers
I need an Imperial freezer gasket for model UL5000ECW4 serial WB01811931.
I have the same model number and my freezer completely defrosted and won' freeze. I assume I have a leek and all the freon (correct spelling) has leaked out any suggestions? My email is bjkirkland@gmail.com.
Mar 02, 2011 | Freezers
What is the best way to defrost a heavy duty commericial Imperial freezer?
a commercial freezer should have it's own defrost cycle. I would look into what the issue is that is causing you to do a manual defrost.
The 2 most common AND safe ways to defrost any freezer is either using hot water or a hot air source such as a hair dryer.
Dec 04, 2010 | Freezers
I need to know which circuit to install for my freezer The description I have is imperial commercial manaual defrost freezer 20.7 Cu Ft.
put it on a dedicated circuit(meaning only item on this breaker) with a minimum of 20 amps @ 120 volts
Sep 23, 2009 | Freezers
Freezers Logo
43 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
