Question about Cameras
Does not take pictures
Upon pressing the "on" button the image diplayed  willl last less then half
a minute then the  "battery exhausted' read out apears . That happens after
the installation of a fully charged  battery.
  • nahuel Aug 23, 2008
    I çm having teh same problem with the batery, it doen t work with the af. What can I do? Do you know any place to repair the camera in Jacksonville Florida?
    Thank you very much
Same problem with the Canon XTi. Often I have to open the battery cap and close it to "reset" the lens to get it to auto-focus.
Posted on Jul 23, 2008
I am having 35-135 sigma macro zoom lens. pls tell me how do i use it in wild life and night photography without useing flash.
how do i set the focus in 50mm.
Posted on Dec 19, 2007
  • 37 Answers
If this is happening on a D200, it is a known issue.  If you remove and reinsert the battery it is often fine afterward.  If it is a different body then it may need repair.
Posted on Oct 23, 2007
My Kindle was fine last night before last. It froze when I got ready to read it today. I tried rebooting it but when it came back on half the screen is visible the bottom half stayed frozen. Is there a...
It could be a hardware problem. Half a screen not working doesn't sound good to me. I have a PaperWhite Kindle. I had another Kindle I dropped and it came up like yours, with half a screen showing the picture and the other half the screen showing white. It's now a paper weight.
You can try a total reboot by holding down the power button for about twenty seconds. Mine hangs up every couple months and the touch screen stops responding and the reboot by holding down the power button for about twenty seconds fixes it every time. It takes a few minutes. You have to sit there and watch the slow progress bar fill in as it goes through the re-boot process.
If this doesn't work, you might try removing the back cover, disconnecting the battery. Letting it set for minute or so and then reconnect the battery, re-install the back cover and try a normal short-power button push first and if nothing happens, follow it with the long power button push.
Mar 01, 2015 | Tablets & eReaders
Hi chicbenzon_1 ,
The LCD picture is clear indicates that the lens is clear enough to capture the image, if there would be any disturbance on the lens you would come to know on the LCD itself.
When you push the button to shoot , it could be that you are pressing the button just half way which is a function used to focus on the object before full press of the button or actual shot of the image.
I would recommend you to half press the button till you focus on your image and then when your hands are steady and there is no shake on the camera , go ahead and press the button full which would result in the image being taken.
Hope this helps ...:)
May 11, 2011 | Olympus FE-320 Digital Camera
I'm having trouble deleting pictures any advice would be helpfull.
normal procedure for deleting images using a dscs700 cam.
1. press playback button (button you use for viewing images, located just above the lcd screen,left side w/arrow icon pointing to the left)
2.salect the image by pressing the left or right control button
3.once image to be deleted is selected, press the delete button (2 black squares w/a slash and garbage can icon,below the control buttons on the left side). delete option by pressing the up control button. middle of the control button to confirm.
...or if you would like to just remove everything on the memory stick including protected images you can just format the ms by: menu to diplay menu settings. right control button to go to setup (looks like a toolbox or suitcase icon) and press the right control button again. the down control button to go to Memory Stick Tool and press right again to confirm selection. right control button to select format. up control to select ok and press middle control button. message will appear telling you that "all data in ms will be erased.ready?"
6'press up control to select ok and confirm by pressing middle control button.format completed.
hope this info helps. thanks:)
Apr 13, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Power failure upon pressing shutter button
dear ur battery is not working properly replace the battery
Dec 14, 2009 | Canon EOS 40D Digital Camera
Incoming faxes do not print, fax report reads 'power fail' and diplay reads 'low memory' - Can you help?
First, does the machine print normally from a computer or when making copies?
If so, then most probably you have enabled a private receive fax mode. In this mode, faxes are not printed immediately upon receipt (to prevent unauthorized people to read them), but are stored in memory, waiting for an authorized person to come and print them, providing a PIN (password).
To print the faxes stored in memory, do the following:
- press FaxMenu
- using arrow buttons select "receive"
- press OK
- using arrow buttons select "print faxes"
- press OK
- using the alphanumeric keypad enter the PIN/password and press OK
THe previously received faxes should print..
SOmeone must have turned this option on, so ask that person what he/she entered as the PIN.
Dec 04, 2009 | HP Laserjet CM 1312NFI Color Printer
My Nikon D40 won't take pictures fast.
Are you pressing the shutter button half-way and allowing the camera to lock in the focus before pressing the rest of the way?
Sep 21, 2009 | Nikon D40x Digital Camera
Image size seems to change
The likely problem is the shortcut button which sits below the ISO button. The factory default for this button is image size. Every time you press it (or catch with your thumb) the image size will change. catch it enough times and it will get down to S (640x480). Why this was chosen as the preferred shortcut is anybody's guess!
The button can be changed to do something else less severe (e.g. cycle the display on/off). This is done via "MENU", then the 1st tab (looks like a camera) then "SET SHORTCUT BUTTON" then select the most appropriate option (page 61-62 of advanced S3IS manual).
It's happened to me several times to once in a lifetime pictures (Ankgor Wat in Cambodia).
Aug 30, 2008 | Canon PowerShot S3 IS Digital Camera
Samsung S73 batteries
i am having the exact problem as you are having have you figured anything out? Thanks!
Dec 27, 2007 | Samsung Digimax S730 Digital Camera
Camera switches off when I press the shoot button
Are you using NiMH rechargable batteries? Digital caemras are real battery eaters and Nickel Metal Hydride batteries are the only ones that can stand up to the drain. Buy ones with the highest power rating yu can get. If this doesn't help, then the power board has started to fail and needs replacing.
Apr 01, 2007 | Fuji FinePix A605 Digital Camera
Cameras Logo
78 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
