Question about Lifan Electrical Supplies
Have a lifan 2200 energy storm generator that shuts off all the time. why?
  • 975 Answers
Make sure the oil is full,there is a low oil shut off
Posted on Dec 29, 2013
Testimonial: "It is full."
I have an energy storm lifan 3600 watt remote start generator and since changing fuel in tank it starts and runs at full rpm only and will not idle down. Any advise on fix would be appreciated.
read you user manual but most small gen sets on starting come up to full rpms and stay there regardless of the load situation
it is the rpms that maintain the output voltage and cycles that has to be correct for when a load is suddenly applied
Jul 28, 2016 | Electrical Supplies
Gas is pouring out of new generator. It seems to leak at point where gas goes into filter.Tightened hose. Still pours. Any ideas
Sometimes gas leaks appears to be leaking in one place when it is actually leaking from another place. I assume that the fuel feed is by gravity from the tank to the filter and to the carburettor. Did you check the hose that is attached to the bottom of the tank? it may be ruptured; check both clamps and make sure that there are no shavings to the hose.
good luck
Apr 23, 2016 | Lifan Energy Storm 2200 Portable RV...
Gas started blowing out the back of the air filter...I noticed the hose connects to a valve that appears loose (spins) is that my issue?
It could be timing off, miss firing ona cylinder, exhaust blocked. when running there is a vacuum on the intake manifold any of the issues i mentioned will cause back pressure. Check also intake valve clearances
Feb 14, 2015 | Lifan Pro-Series 8500ie Electric Start...
Have a lifan 2200 energy storm generator and shuts off all the time
Change the oil, or remove the lead to the oil pressure sensor switch
Dec 29, 2013 | Lifan Electrical Supplies
1991 Geo Storm: intermittent... alt. & brake lite come on (alt is NOT charging) heater blower stops... lites go out heater starts blowing (alt IS charging)
that will all happen from not charging eventuly car will shut off high energy ignition uses a lot ov power and runs the batt way down
Apr 04, 2011 | 1991 Geo Storm
Hp psc 2200 printer will not turn on.
If connected to a power surge protector, turn the protector strip off / on.
Jun 10, 2009 | HP PSC 2210 All-In-One InkJet Printer
Electrical Supplies Logo
134 people viewed this question
Top Lifan Electrical Supplies Experts
Steve
Gene Haynes
Are you a Lifan Electrical Supply Expert? Answer questions, earn points and help others
