Question about Epson AcuLaser™ 2600N Printer
Hex dump sheets instead of printing
The help button on the actual printer won't press and what ever we send to print we just get 3 sheets titled HEX DUMP LIST. one of the cartridges is very low but it does this for black printing as well as colour.
the red warning light is not on so all looks as if it should work. please help
brenda
    Novelist:
  • 118 Answers
This often will occur if the wrong drivers are installed. Try uninstalling and reinstalling your printer software.
good luck.
tony
Posted on May 19, 2009
How do I reset dcp-8045d hex dump mode
Probably the easiest way to turn off the Hex Dump mode would be to reset all printer settings. There should be a reset menu that will allow you to reset the printer to factory defaults. After which it should recognize the new ram and print normally.
Apr 02, 2015 | Brother DCP-8045D All-In-One Laser Printer
I am sending raw data to the printer. Where to find ESC codes for different control ops
This feature allows experienced users to see exactly what data is
coming to the printer. This can be useful in finding software
problems. When you turn on the hex dump function, the printer
prints all commands and other data in hexadecimal format, along
with a guide section to help you find specific commands.
To use the hex dump feature, follow these steps:
1. After you make sure the printer is off, open the cover.
2. Hold down the FEED button while you turn on the printer.
3. Close the cover.
4. Run any software program that sends data to the printer. The
printer prints “Hexadecimal Dump” and then all the codes it
receives in a two-column format. The first column contains the
hexadecimal codes and the second column gives the ASCII
characters that correspond to the codes.
Hexadecimal Dump
1B 21 00 1B 26 02 40 40 . ! . . & . @ @
1B 25 01 1B 63 34 00 1B . % . . c4 . .
41 42 43 44 45 46 47 48 ABCDEFGH
❏ A period (.) is printed for each code that has no ASCII
equivalent.
❏ During the hex dump all commands except DLE EOT and
DLE ENQ are disabled.
5. Open the cover to set the printer off line, so that it will print the
last line.
6. Close the cover and turn off the printer or reset it to turn off the
hex dump mode.
PLEASE CHECK THE LINK TO GET THE ESC CODES:
http://www.mit.edu/~vona/MSim/vona/terminal/VT100_Escape_Codes.html
Hope this helps u ..............
Feb 21, 2010 | Epson TM-T88III Thermal Printer
DCP 8045D Display says Hex Dump Load - What does this mean - How do I get rid of it
I resolved the " Hex Dump Mode" problem
Step1: switch off power
Step2: press and hold Stop/Exit ( Red Color Key ) switch on power supply .......
now no " Hex Dump Mode" problem
Jan 19, 2010 | Brother DCP-8040 Copier
Hex Dump
Turn printer off. PRESS & HOLD PAUSE & FEED buttons after power goes out. While holding turn printer ON, count to 3 & let go. once printer does its checks press the MODE button 4 times to SAVE. the bottom 3 lights will flash 1 time. This should reset the entire printer including calibration, communications & everything to be like it just came out of the box.
May 27, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra 2844 won't print anything.
Sounds like you may have taken out more than the fuse. In case there is still life the next thing to try is a printer reset
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Jan 26, 2009 | Zebra LP 2844 Thermal Printer
Can't print from bottom drawer, will only print from tray,
There are at least three possible solutions. The first two are simple the third is fairly complicated unlr=ess you can read a hex dump of a print file. 1) Use the front panel "Paper Menu" to select the tray. 2) Check the driver settings to make sure the driver is set to "Auto" or the correct tray. 3) Set the driver to "Print to File". When prompted to name the print file, name it "tray_fail". If you do not know how to read this file, send it to me at janddgasrepair@verison.net and I'll be happy to take a look at it and see I I can correct the problem. Don
Jan 16, 2009 | Lexmark Optra S 1855 Laser Printer
Tlp 2844 printing first page ok then prints another blank
First thing to try is a reset of the printer.
5) Push feed
David
Jan 03, 2009 | Zebra LP 2844 Thermal Printer
PC4 doesnt appear to recognize ANY IPL coding
1. Add Generic Printer to printer list.
2. Select Generic printer as Default printer
3. open the document and print.
Jul 14, 2008 | Intermec EasyCoder PC4 Label Printer
Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
Epson AcuLaser™ 2600N Printer Logo
468 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
