Question about Canon PowerShot SD1000 Digital Camera
My screen remains black before and after the picture is taken and i have tried hitting it with the palm of my hand...???
My powershot a640 will not show the screen...it appears black while looking at whatever youre taking a picture of and the picture will also turn out all black...butttttt i can access all the menus and such
    President:
  • 1,223 Answers
CCD FAILURE!
Call canon for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
Service Advisory Link this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
Posted on May 19, 2009
  • Shoaib Rais
    Shoaib Rais May 22, 2009
    I have diagnosed 100% correctly if u have any doubts u can call Canon for the fault u have they will also tell u the same thing , kindly update ur rating there is no solution to ur problem other then the one i have described earlier
    Regards
    Zohail
  • Shoaib Rais
    Shoaib Rais May 28, 2009
    look i have diagnosed correctly and successfully diagnosed every camera
    with this problem u can see my profile , this is a known issue and i am
    trying to help , and it is Free as u know i am not getting any
    financial gain from helping u, the only thing i need is good rating, so
    kindly update ur rating for the solution and more questions are welcome
    Regards
    Zohail
Powershot A640 Could Not Be Powered On, Burnt Smell My Powershot A640 died during a picture shot, lens remaining open. I thought it may be due to the dead batteries. But after putting new batteries and...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Sep 02, 2010 | Canon PowerShot A640 Digital Camera
Camera works but the screen went black A640 except for video and color swap. Did I press a button? I was shooting in cold weather.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
But if you've already tried this, have you also tried downloading any of your photos taken with the black screen to your computer? Are the photos also black? If so, you might instead be experieincing a stuck shutter (possibly due to the cold weather).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jan 03, 2010 | Canon PowerShot A640 Digital Camera
No picyures
Aug 02, 2009 | Canon PowerShot A640 Digital Camera
Lens problem?! Black screen all of a sudden
the iris is stuck shut. try banging with the palm of your hand a few times to jar it lose. if its making crunching noise the gears are broken on lens housing. not econimcal to repair
Jun 04, 2009 | Kodak EASYSHARE M1063 Digital Camera
Powershot A640 Buttons not responding
I would call Canon tech support and set it up for service. They will let you know what your options are. 1-800-828-4040.
Hope this helps!
Jun 02, 2008 | Canon PowerShot A640 Digital Camera
Canon ixus 75 black screen
I tried all the solutions offered on the net and none worked except one. It simply said "hit the camera with the palm of your hand" (when it is on) and the screen will return. I thought, well I have nothing to lose and so I hit it on the side and sure enough the LCD is again working !!!
May 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Black screen on my Canon PowerShot A640
I had this problem too. Try the "DISP" button (bottom left on the display side of the camera. It allows you several viewing options, and is easy to accidentally hit and turn the LCD screen "off."
Apr 27, 2008 | Canon PowerShot A640 Digital Camera
Videos and photos not all readable by computer when taken on Canon PowerShot A640
You will likely need to use the software that came with the Canon powershot vs. just trying to download via the default (scanner and camera wizard for example) program. If you are doing this already, then I don't know why it is not transferring them over to the computer properly, but if you are not using the Canon Zoombrowser software, you should make sure you load the cd that came with it.
Hope this helps!
Dec 16, 2007 | Canon PowerShot A640 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
244 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
