Question about Motorola Mobility H700 Wireless Headset
My Motorola h700 bluetooth will not pair
I dropped my motorola h700 a small distance(of a couch to the floor) and now it will notpair with my Tmobile sidekick 3.  I close the boom and hold the talk button for 5 seconds and it lights up purple. Then when I open the headset boom it will not stay light. So it never enters pairing mode.  Please Help.
  • 15 more comments
  • dquaria Nov 01, 2007
    i have the same problem but i am trying to pair it to a Nextel
  • wyanette Feb 03, 2008
    i don't know how to put the headset in pairing mode
  • yaugustine Feb 13, 2008
    it won't pair with my lg500. don't know what the problem is... the light just come on once when i open the boom
  • keviny24 Mar 21, 2008
    my bluetooth h700 does not want to pair with my sidekick lx, when i want to pair it the sidekick wont find the bluetooth, what can i do?
  • kbrennfo Apr 15, 2008
    Motorola H700 will not enter pairing mode. The purple light will only stay lit until I open the boom then goes off.
  • tanhai99 Apr 18, 2008
    The user guide instructs user to open the boom and the light will turn purple. Well, it didn't happen that way for me. I folded it back in (turned it off), pressed the button for a couple seconds, then the light turned purple. Then I immediately opened the boom. The light remained purple and stayed in pairing mode. I finally got it paired up with my LG Shine.
    This trick is not in the user guide's trouble shooting but it works for me.
  • portugal1 May 31, 2008
    I dont know how to put my head set into pairing mode to connect to my LG Shine , please describe for me
    Les
  • Anonymous Jun 02, 2008
    will not pair with phone and purple light comes on
  • DeLiVega Jun 10, 2008
    i have a motorola H700 and when i try to use it with my PS3 it doesnt work, but whne i go to audio settings in the PS3 panel then it will work... but when i start the game the light will turn off and it wont work... i dont know what is wrong with it... anyone help?!?!?
  • hdset Jul 12, 2008
    NEED BASIC SETUP INSTRUCTIONS FOR H700 HEADSET LOST WHAT I HAD .CAN YOU HELP?
  • Anonymous Jul 15, 2008
    I had the same problem with my razor...someone mentioned the hold it until it turns purple and then immediately (and i mean quickly) open it up and it should stay lit purple...mine finally worked but the trick was opening the boom right away...the manual says hold for 10 secs...no need.
  • mbwoods45 Jul 27, 2008
    i thank you for your solutionn that worked for me but where do i get the numeric password that my phone is asking for?
  • Anonymous Aug 18, 2008
    i cant connect to my ps3
  • mttorres1973 Aug 19, 2008
    The purple light on my bluetooth is not staying lit when pairing. what can I do.
  • kriste500 Jan 08, 2009
    I can't get my motorola h700 to pair with my iphone. the motorola h700 light turns purple so i am assuming it's working.
  • Anonymous Mar 19, 2009
    i can never pair with any of my friends and soem of them says it just because its a motorola phone but how do you go onto pairing mode?
  • Anonymous Mar 16, 2014
    lights up green when plugged in goes off when unplugged wont pair it is used
Rest assured that the drop did not cause this.  There is a general problem with these H700's.
Press the multifunction button until the led turns purple.  Keep it pressed in while you flip the arm open.  The arm needs to be kept fully extended to keep it in pairing mode.  If you succeed in positioning the arm correctly, a steady blue light will be on.  If the light goes off...close the arm and try again.
While in this mode...execute the pairing procedure from your phone...it should find the H700.  The default key is "0000".
Posted on Oct 25, 2007
I dropped mine when i was on top of the ladder. it would not pair afterwards. i opened it up and found that a metal contact piece is missing. it is for when you opened the boom it pushes the metal piece to the cicuit board that activates it. so i made a replacement piece out of reynolds wrap:) I fold it into a little square and placed between the push lever and the circuit board contact for the boom. now it paired like normal.
Posted on Aug 27, 2010
  • riddle910 Aug 27, 2010
    Anyone want to sell their broken h700 to me? For a $1.....?
I have a T-mobile Wing and H700C. I finally got mine to work by pressing the headset control button twice. It made the blue light come on, after the purple light, now I have a partnership between my phone and headset.
Posted on Oct 24, 2008
Thanks it works for me!!
Posted on Oct 21, 2008
Mine keep showing it is paired, but no icon goes on my palm treo 755..shows in trusted devices, gives me a paired message, but no connection...not paying 90$ for another one! this is about 4 months old!
Posted on Jul 25, 2008
Mine is charged fully (Green light on), but when i unplug it from the charger and try to pair it, the Purplr light never lights up. The arm is closed.
Any ideas?
Thanks
Posted on Jul 24, 2008
Nnjnnnnnnnnnnnnnnnnoooooooooooooooooooooooo
Posted on Jun 06, 2008
You should do the same thing as me, by another one....
Posted on Jun 03, 2008
Thanks you so much. I almost bought a new one, but this suggestion saved the day!!
Posted on Jun 02, 2008
It did work for me thanks
1. press till light is purple and open while u still presing
2. on ur cell find the options paring
3. the name or ur bluetooth will come up
4. hight lite the bluetooth name and selecte it
done
Posted on Apr 21, 2008
It doesn't work. it connected for few second then disconnect. i tried it several times and it keep doing the same thing. what i do
Posted on Feb 13, 2008
Thanks, Gladiator7, I was having the same problem and your solution worked for me.
Posted on Nov 20, 2007
Well done, that solution works, it was giving me a headache for weeks. thanx
Posted on Nov 07, 2007
SOURCE:
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
How do I pair motorola h700 with motorola defy?
Enable Bluetooth on your Defy. Then follow these instructions H700 Different Paring Instructions then search for H700 on your Defy.
Mark
Motorola Support
Apr 13, 2014 | Motorola Mobility H700 Wireless Headset
Reset G700 bluetooth with tmobile G1
Hello...
I think you are trying to pair this bluetooth with your tmobile phone... Is this correct?
If so, here is a link to how to pair this bluetooth device... > http://wiki.answers.com/Q/How_do_you_troubleshoot_the_motorola_H700_bluetooth_headset
Hopefully that helps...
Aug 08, 2011 | Motorola Mobility H700 Wireless Headset
How do i put the motorola h700 in pairing mode
Hi terantra,
I would like to assist you with your Motorola H700 headset, Please see steps below.
  • Make sure that there are no other Bluetooth devices in the area.
  • Now set the device that you want your Motorola H700 to pair with make sure that it is detecting devices.
  • Now on your H700 Motorola press and Hold down the Multifunction Button on it, and open the mouth piece.
  • This should be detected right away by the device that you are pairing the with the H700, the pairing Code for this H700 will "0000"
I hope that his will be of help regarding your concern.
Have a nice day,
mvincent
Apr 22, 2011 | Motorola Mobility H700 Wireless Headset
How to pair motorola H700 wireless Headset with my treo 650
Open the headset boom: it will flash steadily purple, it it's not paired ever. If it was paired turn that devices off; open the headset boom, blue will steadily lit; after 5 seconds, it will steadily purple lit. Now find Motorola H700 on bluetooth and type password: 0000. Done!
Dec 18, 2010 | Motorola Mobility H700 Wireless Headset
Bluetooth serial # 6809501a26-0 need
1.Switch on the bluetooth on your phone.
2.Open the headset boom to initiate easy pairing. After a few moments, the indicator light will be steadily lit in purple to indicate headset is in pairing mode..Motorola H700 will be detected.
3.Go to handsfree and select 'look for devices'. 4.Select Motorola H700.Select Yes to bond. Enter the passkey 0000 and select OK.
Thank You
Sep 01, 2010 | Motorola Mobility H700 Wireless Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
H700 will pair, but won't connect.
To successfully pair the Motorola 700 with the Centro:
Select Bluetooth from the Home screen.
Select "On".
Under "Visibility", select "Visible".
Now click "Setup Devices".
Click "Hands-free Setup"
On the Motorola earpiece, with the flip-out mouthpiece in the closed position, press and hold the multi button until ring around it glows purple. Flip open the mouthpiece.
Now click "Next" on the Centro's screen.
The Centro should find the Motorola. Hold the Motorola to the right side of the phone if you have difficulty getting the Centro to find it.
Once found, click the Motorola H700 listed in the window and click "OK".
The Centro will ask for the device password. Enter 0000. Be sure that the checkbox for "Add to trusted device list" is checked. Click OK.
The two devices should now be paired to work together and the Motorola's multi button should rapidly blink blue; NOW click "Done".
You will be taken to the Trusted Devices screen.
You will see your Motorola in the list of Trusted Devices. Click on it to highlight it, if it is not already highlighted.
Click the menu drop-down key (located to the right of the ALT key).
You will now see a drop-down at the top of the screen that says "Connect". Click the "palm" center button on your Centro.
NOW the two devices are connected. The phone name will now be bold, and a small Bluetooth icon will appear to the right of it.
When you click the Phone key on your Centro, you will see a tiny blue headphone symbol now at the top right of the screen where the Bluetooth icon used to be.
To use the earpiece:
Flip it open and hang it on your ear.
Dial the number you want to call on the phone.
Press the multi button once and now you should be connected via the earpiece.
To receive a call, when your Centro rings, press the multi button once.
It took me a few hours to figure it out. Hopefully you can do it in a few seconds.
Dec 28, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
4,045 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
