Question about GE Spacemaker JVM1640SJ Microwave Oven
F5 Error GE Spacemaker Microwave Oven
My GE Spacemaker XL1800 will beep an F5 Error when I try to reheat a little coffee.
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Profile Spacemaker® XL1800 Microwave Oven
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
  • 95 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
vitg55
  • 70 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Posted on Dec 15, 2008
Ge xl1800 not heating and sounds a little different everything else is working fine...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101][][][
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
In model spacemaker xl1800 no heating but all
Microwave Oven Basic Troubleshooting Tips
heatman101
gfj
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave spacemaker xl1800
F-3 means shorted touch panel pad. In order to attempt clearing the code yourself, please follow the steps below:
  1. Press CLEAR/OFF or CANCEL.
  2. Program control again.
  3. If the fault code appears again, disconnect power to the microwave for 30 seconds.
  4. Program the cooking function again.
  5. IF it comes back up you should change out the panel hope that helps, good luck
Dec 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
49 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
