Question about Samsung WF337AA Front Load Washer
My samsung automatic washing machine SW65V5 got the damage the main motor because of overloading and when i change the whole motor and install it. My washing machine continuosly spinning even without
Nathan@gasarabian.com
  • 351 Answers
SOURCE: samsung washing machine WA71N2
can you hear the pump making any noises,if you can (humming sound)then it may be blocked with lint,coins etc.if the pump isnt making any noises then it may be faulty or a broken wire to the pump or you have a no drain button pressed in . hope this helps
Posted on Mar 07, 2008
SOURCE: samsung washing machine ji453s
4e error
Posted on Dec 02, 2008
SOURCE: My washing machine wont spin or move.
All fixed - it was the belt that needed replacing
YAY no need to buy a new one
Posted on Aug 25, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 327 Answers
SOURCE: OE code keeps flashing ; door remains locked
Hello, an OE error presents if the washing machine has not successfully drained the water in ten minutes.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confirm that the washer is leveled from side to side and front to back.
Thanks
Posted on May 20, 2010
My Fisher & Paykel 8.5kg Washing machine (WH8560J1) vibrates and makes a very loud noise during washing cycle. The vibrations is that bad the whole machine moves of its base. What is the problem?
Main Bearing worn, time for an overhaul! get it looked at sooner rather than later, as motor and shaft damage can occur. it's expensive, sorry to tell you, but cheaper than a new one!
Jul 18, 2017 | Fisher Washing Machines
Tip
Simple Tips to Make Your Washing Machine Last Longer
  1. DON’T OVERLOAD: Overloading not only is damaging to your clothes but also puts unnecessary stress on vital components. Compare overloading your washer to pulling a loaded trailer behind your family car all the time. Extra strain on the motor, transmission and suspension will most certainly shorten the life of your car. Oh, did I say your washer also has a motor, transmission and suspension?...How does overloading damage my clothes? Rubbing together of cottons causes linting. The more rubbing together the more linting and the shorter the life of the garment.
  2. DRAIN HOSE HEIGHT: Be sure to follow manufactures directions regarding proper installation. Washers have small pumps, either self powered or driven by belt off main motor. Ideally, the drain hose should hook into a drain pipe directly behind the console of your washer. If your hose is too high the pump takes longer to evacuate the water from the tub putting stress on your washer and possibly reducing cleaning effectiveness. Too low a drain hose and your water could siphon out of the unit during the wash cycle. I have been on calls where the customer said there washer would wash, stop, fill, wash, stop, fill etc. Water was siphoning from the tub.
  3. RUSTING: Clean surfaces frequently to avoid rusting, especially clean around the bleach dispenser as bleach is corrosive and will cause severe rusting if not kept clean and dry. If rusting has already appeared go to your hardware store and pick up a bottle of rust converter (not rust remover). Follow directions on bottle. This works very well on rust. It can also be painted over after 24 to 48 hours.
  4. SOAP SCUM : To reduce the build up of scum fill your washer with warm water, add a pint of vinegar and let it run through a full cycle.Follow this procedure once a month.
  5. BUY OEM PARTS: When replacing parts on your washer, be sure to buy genuine Whirlpool parts, Frigidaire parts, Kenmore parts, Maytag parts, or parts for whichever brand washer you have. This will guarantee you are using the most reliable replacement parts available.
on Dec 22, 2009 | Washing Machines
My Samsung WA13V9 washing machine doesn't drain or spin, but I think the pump motor is working. where can the problem be?
Check that the wiring inside is not damaged, if ok check that the start timer is not stack, if ok check that the drain pump is not blocked eg a coin stuck in it, if ok check that the start capacitor for the main spin motor is ok if not replace with same rating, if ok check if main spin motor is ok eg using continuty tester to check windigs or simply smell it and if burnt expect a pungent smell from it.
Aug 03, 2015 | Samsung Washing Machines
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
Yeah I have a small whirpool washing machine. I stuffed it with too many clothes & it overloaded therefore causing it to smoke... So I unplugged it before it had a chance to really heat up! So the next...
Overloading the machine puts extra strain on the motor and the smoke you saw was most likely coming from the motor. As you unplugged it and it ran normally the next time, you may have avoided doing any damage - or at least serious damage - to the motor.
You should be able to continue using the machine with no problem, but don't be too surprised if your motor quits in future. If you are using the machine again and you notice smoke - whether you've overloaded the machine or not - switch it off and have it replaced or at least inspected.
Regards,
BElectric.
Dec 06, 2010 | Amana NAV8800E Top Load Washer
My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
If the motor stops working, in one direction ten times, “8E” Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
would advise calling a tech... hope this helps.
Oct 25, 2009 | Washing Machines
E8 error code
8E - OVER CURRENT ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Samsung p1253
LE means locked rotor or overload in motor. Check for binding or mechanical resistance. check motor winding resistance. Also check 3 pin connector in motor harness, harness between stator and main board or Hall Sensor on motor could be defective
Dec 28, 2007 | LG WM-2277HW Front Load Washer
Samsung WF337AA Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
