Question about Breville Juicers
The extractor filter is stuck
The extractor seems to be wedged in
Where can I get the filters?
Hi Rue,
Here is another from Amazon to crosscheck Acme Replacement Juicer Filter Liners for Model 6001 or 5001 200 Pack .
Here is another source of 600 filters for a modest price. Acme Juicer Juicers at Discount Prices
Jul 27, 2014 | Acme 6001 Juice Extractor
Russell Hobbs Juice Extractor Won't Start
if it is intermediate workings there is a micro switch that is a must so it wont turn on when your fingers are in it might have some junk in it clean your machine. look if the micro switch fell inside machine ?
May 12, 2014 | Juicelady JL500 Juice Extractor
The cutter is stuck how can I get the cutter off of the champion juicer?
I have had this happen in the past...couple things you might try.... put it outside or in the freezer to cool it down. next i have dumped olive oil 'around' the end of it that is butted against the unit- some should seeps down and then i used a dull butter knife or steak knife to wedge in there to pry it off.(genlty) in different positions. If it is rusted on, well that's another matter entirely. But if it's just stuck, could be that you haven't oiled it each time? or my other guess is they aren't making the cutters like they did 25 years ago as i have had 3 champtions and more problems with the new ones and cutters jamming (i put a coule drops of olive oil into the hole in the cutter each time). and as a last resort a big burly man with gloves and feet to hang on to it and jimmy it off LOL good luck ;-)
Jan 08, 2011 | Champion G5NG853S Household Juice...
How do I take apart the strainer section?
Everything should just lift up and off. May be
juice stuck together. Try a little tap to the whole
assembly.
Mar 04, 2010 | Acme 6001 Juice Extractor
Juice extractor 67800 350 Watts, The problem is the cutter strainer gets stuck and I can only get it off after much effort and struggle, is there a simpler way ,Margaret
As soon as I had described the problem I found the solution. A smear of olive oil around the inside of the base of the cutter, and around the seating of it, on the unit. And it worked. No problem.
Nov 04, 2009 | Hamilton Beach 67800 HealthSmart Juice...
Sometimes it will spin out of control the lid pops off and its scary! This seems to happen when I juice cucumbers even though I take the seeds out. Yesterday I juiced lettuce leaves, celery (2 sticks),...
DROP THE FILTERS. FRUITS AND VEGETABLES HAVE TO BE FED SLOW
AND STEADY. IF THE JUICER IS OLD THE
GAP BETWEEN BLADE AND CHUTE MAY
BE TO WIDE LETTING LARGER PIECES
THRU AND THROWING IT OUT OF
BALANCE. USING ONE FOR 19 YEARS
AND THEY ARE TRICKY.
Jul 16, 2009 | Acme 5001 Supreme Juicerator Juice...
Cutter is stuck onto shaft, how can I remove it?
First, check to see if there is a set screw in the side of the cutter which screws against the shaft.
If no set screw, a gear puller would probably do the trick. There are many types -- you might luck out and find one which will fit on your first shopping trip.
Apr 29, 2009 | Champion 2000+ Household Juice Extractor
Acme 5001 on / off button
REMOVE THE 4 BOTTOM SCREWS AND
TRY IT AGAIN. YOU CAN SEE THE SEAM
AROUND THE JUICER WHERE IT SEPARATES.
YOU CAN GET THE SWITCH FROM WARING
AT 800 492 7464. MINE IS FROM 1990 AND
RUNS LIKE NEW. DO ALL MY OWN REPAIRS.
Mar 10, 2008 | Acme 5001 Supreme Juicerator Juice...
Pulp gets stuck in Champion
Feed it slower. Mix up the items, it likes things mixed up. You can add water near the end to clean it out.
Jan 20, 2008 | Champion 2000+ Household Juice Extractor
Juicers Logo
22 people viewed this question
Top Breville Juicers Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
eyecam
Are you a Breville Juicer Expert? Answer questions, earn points and help others
