Question about BOSS AUDIO SYSTEMS 612ua
Boss radio antenna hookup doesn't fit - BOSS AUDIO SYSTEMS 612ua
How to install a boss bv9982 7 inch single din?
You will need a GM dash kit designed for 2004 Impala (see picture below)...Lower steering...Remove radio...Unplug harness and antenna...Boss wiring matches colors wire for wire in factory plug...Splice one wire at a time to matching color...Plug in antenna...However it is much easier to buy a plug-n-play harness ($25) designed for your vehicle eliminating the need to splice...The Brown wire goes to ground via switch...saailer
4c37a5a7-0e7a-40b3-86da-e0f7039aac1f.jpgCost $15
May 05, 2014 | 2004 Chevrolet Impala
Why my bv9562b says gps not supported
In the Boss manual, that radio doesn't even mention gps. I suspect it doesn't come with the antenna, and other electronics necessary for gps functions.
http://www.bossaudio.com/manuals/
Manuals Boss Audio Systems
Apr 23, 2014 | GPS
How to install boss 612ua in 2004 dodge stratus
Have a wiring harness for your vehicle if not get one and have a dash kit that fits your vehicle now plug the new harness into the plug that came from your stock radio now match all the wires from the stereo to the harness twist and tape if you can't solder also may need an antenna adapter to fit your new stereo all wires should be labeled and it's ok if there are a couple you don't use
Jan 31, 2014 | BOSS AUDIO SYSTEMS 612ua
I pulled my ipod to car lighter hookup out of the car lighter today and the entire thing popped out. i put it back but now my radio won't turn on... at all. my antenna won't even go up. i don't know what i...
in some vehicles the 12 volt power plug in is on the same fuse as the radio or console, as for the antenna not going up that makes sense, the power for the power antenna is most likely supplied by the radio, no power to the radio no power to the antenna. good luck and I hope this helps.
Aug 10, 2010 | 1990 Volvo 240
Will the Boss BV9555 fit a 2004 F150 ( new body style) super cab with factory stereo .
the radio is double din but the opening is only din and 1/2. it would fit but requires some customising
Feb 06, 2010 | Boss BV9555 Car Video Player
HDTV Converter hookup with sat. and antenna
Hi there Phil...... this switch from analog to digital has lots of folks scratching their heads. Fortunately I have some great news for you. The signal coming from the Dish network does not need a converter as it is already digital.
May 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
BOSS AUDIO SYSTEMS 612ua Logo
27 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
