Question about Altec Lansing VS4121 Speaker
ALTEC LANSING VS4121 crackles when on. WHat possibly is the problem?
When the speaker is on, a crackling sound is intermittently produced.
  • 205 Answers
SOURCE: Altec Lansing VS4121 no sound
If removing and reinstalling the driver fixed your problem then there was nothing wrong with the speakes. There was probably a problem with your soundcard drivers.
That being said, you should double check that you speakers are plugged in to the right sound board connector and the power supply is plugged into the wall outlet.
Does you computer have a headphone jack? If it does, you might try plugging a headset into it to see if you can hear sound there. If you do then you'll know the soundboard is working properly and maybe the speakers really are part of the problem. CD/DVD drives usually have a headset jack, but this will only work if a cable was run inside the computer from the CD/DVD drive to either the soundboard or motherboard.
What kind of computer do you have? Do you know if you have on board sound or a seperate sound board?
Posted on Nov 19, 2007
  • 238 Answers
SOURCE: altec lansing vs4121
u dont need any driver to play the speakers, yes the sound card does, take down ur sound card modle no. and try looking in www.driversguide.com let me know.
Posted on Feb 14, 2008
SOURCE: No Power (LED off) in the Altec Lansing VS4121
There is a fuse on the power supply board which is held in place with 4 screws. Yiu will have to unplug the sub-woofer connector to remove it.
Posted on Apr 15, 2008
  • 11 Answers
SOURCE: Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Posted on Sep 17, 2008
SOURCE: my speaker altec lansing vs4121 is just humming
Check the audio amplifiers Ic´s maybe are burned
Posted on Aug 10, 2009
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
Altec lansing vs4121 speaker boom sound
you may have blown out the speaker or there is a miscommunication between the laptop and the woofer
Jun 15, 2012 | Altec Lansing VS4121 Speaker
My Altec Lansing VS4121 is having a sound as if it is grounded or something. First I thought it was just a wire connecting to my pc but it isn't. I tried to unplugged it to my pc but still producing the...
Hello Adrenalize, hi, you may be right, but also check other ICs as well, the humming sound can be caused by the amplifier or its preamp section, this is where the 1036 (this is a dc operated tone control) is located. But before replacing the 1036, try first replacing the POWER AMP IC. (my experiences with those humming sounds usually are caused by IC amplifiers and op-amp ICs.)
Dec 05, 2010 | Altec Lansing VS4121 Speaker
Is is possible to install altec lansing speakers
It is possible to hook up these speakers to a laptop according to this brochure:
http://www.alteclansing.com/images/spec/vs4121%20sell%20sheet.pdf
Now this manual shows those speakers being hooked up to a computer but laptops have the same outputs as well so here it is:
http://www.alteclansing.co.uk/images/quick/vs4121qcc.pdf
you'll need adobe reader to read the manuals.
May 17, 2010 | Altec Lansing VS4121 Computer Speakers
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
My speaker altec lansing vs4121 is just humming
Aug 10, 2009 | Altec Lansing VS4121 Speaker
Regards, Andrew
Sep 17, 2008 | Altec Lansing VS4121 Speaker
Feb 12, 2008 | Altec Lansing VS4121 Speaker
Altec Lansing VS4121 Speaker Logo
103 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
