Question about Casio G-zone Commando
Gzone battery wont stay charged - Casio G-zone Commando
My Casio gzone commando c811 says it's fully charged so I unplug it and start using it and it all of a sudden dies why?
probably a memory problem in the battery
if they are continuously being recharged when not close to 5% then they develope a memory level and will not charge past that point
the fix is a new battery
Mar 21, 2016 | Casio Cell Phones
Wont charge says usb tried six different chargers
Try new battery. Check mini usb port of your cellphone for mis-align contact pad or pin
Mar 10, 2015 | Casio Gzone Commando C771 - Black verizon...
Why my battery on my 1996 Honda magna vf750c wont stay charged
How old is the battery? Will it hold a charge if you have it charged by shop or Auto parts place? Have you checked the cell water level? If low use distilled water only, be careful, inside is acid that will burn your skin or anything else. If It is a good battery, you have switches that are staying on, or a short to ground, bare wires next to the frame somewhere.
Feb 26, 2015 | 1996 Honda VF 750 C Magna
Battery wont stay charged on simplicity broadmoor
Alternator ? is the charging light of your car stays on ?
Oct 15, 2012 | Cars & Trucks
Have 97 acura won't stay charge changed battery
the battery wont stay charged? if youre putting in a fully charged battery and your car runs, but then the battery slowly dies, the problem will be your alternator. the alternator is what maintains a car batteries charge. try replacing the alternator. hope this helps.
Aug 15, 2011 | 1997 Acura Integra Type R
The phone won't take a charge. The red light comes on indicating that it is charging but it doesn't. What's the deal?
Try this.. as it works for me on my GzOne Rock..
Connect to the charger just long enough for the screen to power on, then immediately disconnect the charger before it goes into charging mode. . -- It should power up and be ready for use.in a couple seconds.
I have found that only when the battery gets completely drained, that the Gzone Rock often will not power back up on it's own, even though the battery has been successfully recharged.
By connecting the to the charger it will initiate the boot-up of the phone - but you must remove it before it displays the charging screen again, otherwise it still won't come on and boot.
I don't know why, but this method works for my GzOne Rock every time.
Jan 31, 2011 | Casio G'zOne Rock Cell Phone
Tomtom930 wont stay charged..cahnged the battery
it sounds like your power adapter isn't supplying enough power to the unit. You should be able to try switching out the adapter with another and see if that helps. If the doesn't help, then there may be a problem with the recharging circuit on your GPS. AT which point you should contact TomTom.
Feb 22, 2010 | Tomtom GO 930 GPS Receiver
Casio gzone type-v cell phone put power supply in heasdset port now wont power up
Have you ever heard the term PAPER WEIGHT. You just pumped about 5 volts of juice into something that puts out milli-volts. I would say its toast.
Best bet would be to take it in to Verizon and play stupid, maybe its under warranty or you have or can get insurance on it.
Sep 21, 2009 | Verizon Communications G'zOne Type-V...
My Gzone got knocked into water wit the port open and wont start
After getting a phone wet, the best way to dry it out safely and quickly is to pull the battery and bury the phone in a bowl filled with (uncooked) rice for a day or more. The rice acts as a desiccant and remove any excess moisture.
You may be able to try a different battery after you are sure the phone has dried properly.
Hope this helps you.
Jul 10, 2009 | Casio G''zOne Type S Cellular Phone
Wont charge and get get it to stay on,
Check Power supply first.
use another one and check if battery is charging.
Jan 12, 2009 | HP Pavilion ze5270 PC Notebook
Casio G-zone Commando Logo
18 people viewed this question
Top Casio Cell Phones Experts
Computer Repairing
Computer Repairing
Josh Whitehead
Josh Whitehead
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
