Power prob My desktop computer does not turn on anymore. I've tried everything! I tried other electric sockets in my home & my mother's home, I tried a new power cord, I went on the HP support website & followed all their steps & I opened the side, but everything seems okay. Should I just buy a new one? It's only 14 months old.
  • luvdoctor Nov 13, 2007
    i havent used my desktop for a while after getting my laptop i went to switch it on i have no power at all its not alive was working b4 i checked the cables etc but nothing can any 1 help me please
  • readybk Jun 28, 2008
    Desktop 3l00 when shoving the button in on the harddrive, computer doesnot turn on, power button blinks. The cable on back side with telephone like connections that goes from harddrive to cable box, also blinks on the back side of the harddrive.
  • 91 Answers
Remove all the cable from the back of your cpu accept monitor cable.
remove the ram and reinsert it again.reset your BIOS by removing battery(CMOS). Switch on your computer without battery if starts then change the battery. see whether any capacitor is damaged (pop up).
try this and reply.
Posted on Oct 18, 2007
  • 3 Answers
I have sometimes solved this problem by moving the cvoltage selector switch on back of PC by power cord to 230 and then back to 115.
Posted on Nov 13, 2007
My pc desktop wont work its my tower cuz i tried the monitor on a different pc so what could it be
I would think it is either you motherboard or your power supply. I would start by looking at the power supply. You can pick up a tester at any electronics store. Even at that most of the time electronic stores will test the power supply for free. If it isn't that then I would check out the mother board.
Jan 27, 2013 | Acer Aspire Computers & Internet
I am getting a message that says no signal when I turn on computer
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they might be faulty
a computer needs its power and data to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
hope this helps you
Dec 08, 2011 | E-Machines eMachines Desktop PC
I have a K8V-MX motherboard. Recently, when i start the computer i will sometimes get no video, sometimes i will. When it doesn't work the monitor just goes into power save mode. Everytime everything...
that happend to me aswell, coz the asus motherboard are like that.
1st unplug all the cabels from the mother board like, harddrive ID and Cd-room ID, leave just the power supply on and try to start Your computer if it doesnt work take off the cabels of USB or anything else that is connected in the motherboard and try to switch it on, if that doesnt work.
get another graphic card and try with it maybe u have prob with ur graphic card, and if that doesnt work take of the motherboard from ur case and try to switch it on like that coz ASUS MOTHERBOARD are really silly sometimes.
hope that Helps.
Sep 20, 2011 | ASUS K8V-MX Motherboard
When i have it plugged in it will turn on and work for 5 minutes or so and then it will turn off and same thing with when it's unplugged. what the problem?
It sounds like your CPU is overheating. You've not mentioned whether a laptop or desktop PC.
Desktop - disconnect everything, take it outside if not raining and clean out all the dust and rubbish you can, I ( VERY CAREFULLY) use a dry paint brush. Pay particular attention to the CPU fan and heat dispersal block. More or less in the middle of the mother board, try and clean out the metal vanes. Also clean around the PSU fan assembly. Check all cables are good and home. Re-assemble and try again.
If it keeps on, its probably best to talk to someone who knows a bit more, or, as above, remove the CPU fan assembly and heat dispersal plate, clean CPU but leave it in the mother board, also clean the heat dispersal plate, (The goo is heat dispersal grease to ensure good contact between CPU and plate) Replace the grease and re-assemble.
A tip is to connect the power supply just before putting the case cover back on, powering up and checking that the CPU fan is working OK.
You can get loads of tips and videos from You tube.
If a laptop, the clear out the dust in the vents on the side and underneath, if that doesn't work, it means dismantling your laptop to clean it out. Your still trying to achieve what I've described above.
Sep 03, 2011 | Computers & Internet
I moved my home office desk a few days ago. I properly powered down my computer and unplugged everything. When I reconnected everything, the computer won't power up.
1 - Make sure you have power to the outlet you plugged the computer into. 2 - Make sure all of the cables plugged into the back of the computer are firmly seated / attached.
3 - Check that the switch on the back of the computer (usually quite near the power cord) is turned on.
Jan 06, 2010 | Dell Computers & Internet
Computer wont turn on, beeps with ram removed
plug everything back in and power up the pc when it gets to the error beeps count them then if you can check online at http://networking.ringofsaturn.com/PC/beep.php for a clue as to what the problem will be.
Oct 09, 2009 | Sony VAIO VGC-RB52 PC Desktop
Computer turns on then immediately shuts down
Check Ram first try changing it other wise ur Mother board is giving fault try ram first try re installing it , check the power as well
Feb 20, 2009 | HP Pavilion a1010n (PS563AA) PC Desktop
Can't turn on
sir i guess this is a power supply issue u should change ur the power supply box that u ve inside ur desktop
Aug 13, 2008 | Computers & Internet
Computers & Internet Logo
241 people viewed this question
Alun Cox
David Payne
David Payne
