Question about Garmin Nuvi 660 GPS Receiver
How do I turn off our garmin nuvi?
We used our garmin on a trip and when we unplugged it from the car oulet the screen would not go blank and /or turn off. How do we turn it off? My nuvi 660 won't turn off when car charger stops. Screen stays on instead of turning to blank dark screen
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Why isn't the on/off power switch working? If you press the on/off power button and hold it until the screen goes off, this should turn the unit off.
    Also when you disconnect it from an external power source, a screen should pop up and ask you if you want to turn it off or keep it on.
    While the reset button will turn the unit off, it's not the primary way to do it.
    - Jim
    SHARCNET-USA
  • 385 Answers
Reset button behind the Antenna, press this in for a few seconds.
Use the Web-updater at Garmin, to update it too,
Jack it to a PC and run the update,
If still playing up, Use the Firmware update at Garmin for it,
(( google Garmin 660 software updates ))
Should be good then
Regards
Richard.
Posted on May 19, 2009
We have A Garmin 1300. It works fine for a while then the screen goes blank. We hold down the on button for a LONG while then the screen will come back up and make you go through several screens, but...
Be sure to update the firmware by running the Garmin WebUpdater.
Download and Install WebUpdater.
It is not necessary to unplug the vehicle power cable as the unit will shut down automatically if the vehicle power source is not supplying power after the vehicle is turned off. If the vehicle power cable does continue to supply power, then a manual shut down can be done with the power switch on the nuvi but it is still not necessary to disconnect the vehicle power cable.
Aug 12, 2011 | Garmin nuvi 1300 Car GPS Receiver
Garmin 1200 screen is too dark to read when plugged into my car with the supplied Garmin connector. When I unplug from the car and turn it on the screen works, plug into car doesn't work. I just was on a...
I would go to Tools....Settings...Display.... check your Color Mode is it check on Auto...Daytime or Nighttime pick one then press OK
On the Brightness press it to set it brighter or darker then press OK
Oct 30, 2010 | Garmin nuvi 1250 Car GPS Receiver
Turned on the Garmin nuvi 1200. the Garmin logo comes up, loading maps comes up then it goes blank and begins the cycle again. I have held the power button down nothing. I have touched the bottom right of...
Hi! Please try inserting a paperclip on the reset button. Press hold for atleast 15secs. and this can resolve the problem. Hope this helps and thank you for using FixYa!
Oct 16, 2010 | Garmin nuvi 1200 Car GPS Receiver
Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
Feb 05, 2010 | Garmin nuvi 250W GPS Receiver
I have a garmin nuvi 1300 and then i turn it on
it should show "loading maps" try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update, if not contact supplier for fix/replacement
Nov 03, 2009 | Garmin nuvi 1300 Car GPS Receiver
My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Sep 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Our Garmin Nuvi was working until we stopped the car.
I've had this happen on three successive Nuvi 760's which I sent back, the serial numbers all suggested that they came from the same production batch..
Eventually I got a Nuvi 770 which has been fine. I understand that it's not a problem with the basic design as the 770 is really just a 760 with more memory, but it's probably a fault with a batch of components used during a production run.
This is not a DIY repair; contact Garmin even if your unit is out of warranty as they might offer a goodwill repair for free or at reduced cost.
Jul 03, 2009 | Garmin Nuvi 760 Car GPS Receiver
Slide the on/off switch to the left and hold it until the screen turns off.
- Jim
SHARCNET-USA
Apr 08, 2009 | Garmin nuvi 250 GPS Receiver
Garmin Nuvi 255 won't charge with the car charger.
You may need to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Feb 21, 2009 | Garmin Nuvi 255 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
309 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
