Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer will agitate and drain but not spin; some oil underneath cabinet
Whirlpool Ultimate Care II washer will agitate and drain but will not spin. I thought it was drive coupling that needed replacement, but as I moved the washer out to begin the repair, I see a very small amount of oil has sprayed around the base of the cabinet from underneath. Before I take it all apart, is this still likely a drive coupling issue?
    Scholar:
  • 85 Answers
Coupling may be bad bad the oil is coming from your transmission. It may already be locked up but certainly will eventually as oil gets lower. No real way to fix but to replace transmission.
Posted on May 19, 2009
Whirlpool ultimate care heavy duty leaks underneath, not agitate or spin. only humms and fills up
Again!! Any washer that does not drain has a bad Drain Pump. Very Common. I see this in 40-50% of the problems. Replace the drain pump and your washer will be very happy
Jan 19, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
WHIRLPOOL LSQ8520JQ0 WONT DRIAN OR SPIN, HOW DO YOU REMOVE THE TOP CONSOLE, WHERE THE DIALS ARE
This video will show you how to open the control panel(and remove cabinet) what i would check if it agitates yet wont spin or drain is the lid switch
Gene
Aug 07, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool ultimate II washing machine fills up and agitate but does not spin or drains the water out. how can I fix it.
You have a bad motor. Your washer is a direct drive machine. It turns in one direction to agitate and the other direction to both spin and to pump. You have lost one direction in your motor.
Oct 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II washer won't spin clothes more dry than soggy
Tip the washer backward, inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin. The gearcase and clutch will have to be replaced if oil is present. Check the owners manual for limited warranty on the gearcase. If oil is not present, the clutch is just worn and should be replaced.
Oct 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't start spin cycle
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Addl Info: Our Whirlpool Ultimate Care II washing maching agitates fine, but will not spin.
The spin tub mounting block is probably stripped on the basket drive. Remove agitator. Now put machine into spin do you see shaft spinning but the tub isnt moving???
Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
