Question about Smeg Ovens
Can't get top element out to clean smeg oven
Smeg model S380X-5 Type NO66K - can't get top element out to clean oven
SOURCE: Smeg oven diplaying an "A" in display
Alright - I am the person who left the message before. I left the oven on for a while with the A showing and the time started ticking away. I then pushed the end of cooking time button and then the button that switches the oven back to manual. Hope this helps you. Good luck.
Posted on Sep 30, 2007
vest6
  • 196 Answers
SOURCE: smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Posted on Jan 26, 2008
TaPuna
  • 70 Answers
SOURCE: smeg oven model SA708X--Clock faulty
hi, if you have a faulty clock it is likely the relay in the clock is stuffed you could try to repair it but i think you are better off just buying a new clock, clocks are expensive thou, so bypassing is a good choice
Posted on Sep 09, 2008
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
Replace heating element in smeg oven
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Mar 02, 2013 | Smeg Ovens
SMEG OVEN BRAND NEW WON'T HEAT
Sep 08, 2012 | Smeg Ovens
Fixed fan element, but can't remember how to put it back together again
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jun 22, 2012 | Smeg Ovens
Oven and grill not heating up, model no se 336ss-5
Dec 04, 2011 | Smeg Ovens
I have a smeg oven model SE335SS-5 I think that the element has gone however there is no obvious damage to the element. When I was cooking the house circuit breaker tripped and the oven works fine apart...
Feb 13, 2011 | Smeg Ovens
How to fit a fan element for a smeg se335ss-5 oven
Jan 31, 2011 | Smeg SC712U Oven
RCD trips -suspect faulty element
Go to www.smeg.com and find your country. Go to "After Sales" and select "User manuals". Type your model number in the box and you will get a PDF of the user manual!
May 27, 2010 | Smeg Ovens
Thanks.
Dec 15, 2008 | Smeg Ovens
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Nov 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
19 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
