Question about Kenmore 15864/15862 Top Load Washer
How to remove an fill valve on kenmore 110 92281100
I need to replace the water fill valve, but I can't seem to get to it. Does the back come off? I can't lift the lid either.
catriver
  • 878 Answers
SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Posted on Apr 15, 2007
SOURCE: Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Posted on Jun 25, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore 110 Series 90 stops at the rinse cycle full of water
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. hence, the reason why you can get it to work sometimes by lifting and closing the lid. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
NOTE: For future reference, it is strongly recommended that you do not slam the washer lid or place heavy objects on the lid. This can cause damage to the lid switch.
Posted on Aug 19, 2008
  • 127 Answers
SOURCE: kenmore he3 series washer keeps filling with water when not in use
Remove the 3 screws at the back of the machine that hold the top on. pull back on the top and lift the top off. Remove the hose from the inlet valve and remove the screw that holds the inlet valve.
Posted on Dec 23, 2008
TheMobilian
  • 8220 Answers
SOURCE: Water fill valve on Kenmore series 90 top fill washing machine
To get into the machine read THIS first.After you have accessed the innards then you can easily remove and check the water valve. . Hook the water up to the valve. Get a suicide cord and apply 120 vac to each of the coils and see if they open.
Posted on Jan 21, 2009
I have a kenmore elite washing machine model 110.24952301. Just the other day it stopped filling with water. It agitates and goes through the cycle normally but doesnt fill with water at all. I have...
You are correct. Both fill valves will not go out at the same time. Them problem is with the temperature control board. I change them all the time for this condition. Here is the part to order. To access the control board just remove the back of the console.
Dec 10, 2012 | Kenmore Washing Machines
Unit does not fill with water
Need to gain access to water valves by removing back cover. place a tester on the cold water valve and see if there is power present once program is selected to run.. If there is, your valve is faulty. Replace
May 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore front loader will fill with 3 or 4 inches of water on it's own, when it is off and door is ajar??
Hi, possible your water intake valve are faulty, check back of machine where your( 2) intake water hoses are connected, shut water off, remove and clean water valve, it's possible you got high water pressure in you home (building) or your water valve maybe strain, or has a mechanical fault inside of it, you can remove back of machine, remove water solenoid valve, put valve apart and clean plunger, put valve together and see if same thing happened, if water still comes in after cleaning valve, you should replace it. before doing any repairs unplug machine, (disconnect power) good luck.
Aug 13, 2009 | Kenmore 44102 Front Load Washer
Ice maker seems to be dripping water onto ice in ice container
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Ice maker tray does not fill with water
replace the duel inlet water valve on the bottom back of frig.,one side has failed-mike
May 22, 2009 | Kenmore Refrigerators
Front Load Washing Machine Filling On It's Own
the inlet valves are shot. what happens the coils in the inlet vales can no longer hold the water from going into the unit, causing water to run into unit when not in use. replace the inlet valves and you should be good to go. the inlet valves can be removed by, removing top panel(3screws in back), disconnecting hoses, taking the small clamp on the small hose connected to the dispenser. theirs a small screw holding the inlet valves from back pane, remove old inlet valves and replace and you should be all set. hope it helps.
Apr 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My kenmore 70 series wont stop filling with cold water. the hot water stops filling.
you need to replace the water inlet valve on back of washer as the cold water side is not opening,it's easy,remove the 2 top head screws,flip the head up,use a screw driver to pop the 2 clips out(1 on each side top),unplug the wire jack,now pull the back,back so you can get to the valve-mike
Mar 21, 2009 | Kenmore Washing Machines
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
No water in unit
My dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
Dec 14, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore he3 series washer keeps filling with water when not in use
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 15864/15862 Top Load Washer Logo
21 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
