Question about Panasonic CT-36SX12 36" TV
Hi my panasonic TX-P42S10B tv has just switched off, the red led flashes five times then stays off for about four seconds. tried power button on the front, unplugging and the standby button on the remote. Can anyone help please
techman
  • 3130 Answers
SOURCE: panasonic colour tv TX-29P150X (Made in Malysia)
sounds like you have a intermittant thermal condition and this could be the regulator IC the video jungle/sweep Ic. Anything in the switching poewer supply or sweep curcuit. This is a hard one unless your there with a meter and a schematic to measure voltages when the set goes out then you can use a can of freez sprasy to lightly spray on the supected part. Sorry i cant be of more help. Good Luck
Posted on May 17, 2006
Orbixx
  • 133 Answers
SOURCE: panasonic ct-36hl43 tv
This is usually down to a safety feature cutting out the Television from harming itself. Or quite possibly a fault that make it turn itself off - it may well be thinking it's receiving the command to turn itself off. Either way, it's impossible to find out without opening it up. A professional repair is the only way, check up on your warranty. You may want to plug it into a different power source, just on the off-chance that it may solve your problem - but don't get your hopes up.
Posted on Sep 07, 2007
jingjao
  • 252 Answers
SOURCE: Panasonic CT-36HL43G five blinking lights
check the horizontal transistor
Posted on Sep 29, 2008
supermn4u
  • 16 Answers
SOURCE: Panasonic TX-28PM1 TV
Have you tried pressing the input selection button right after powering on the t.v.? Some t.v.'s go into standby mode when they are on a input selection that has nothing connected to them. Hope this helps some! Best of luck to ya!
Posted on Feb 16, 2010
SOURCE: Panasonic: Switch from 'standby' to 'on' without remote?
No solution I'm afraid, but I also have this problem. Please help Dexstar and me: a turbulent two-year-old needs his Cbeebies!
Posted on May 02, 2010
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Oct 14, 2017 | Sony Televison & Video
Panasonic TX-L42E5B blinks 3 times which board is faulty
When an abnormality has occurred to the unit, the protection circuits operate and set the unit to stand by mode. At this
time the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Fault maybe on the A board 3.3V SOS give me your email & i send you the full timing chart.
Apr 04, 2016 | Panasonic VIERA TX-L42E5B 42" LED TV...
Red LED blinks four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 26, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic TX-L42S10B has power but won't turn on
ok, this may be a silly question but when you turn it on and it starts flashing red, have you tried pressing the stand-by button on the remote. if a tv has been put on stand-by by the remote, and is then switched off by the set, when the set is turned back on it is still in stand-by mode and you need to press the stand-by button on the remote.
other than that I don't know.
Nov 08, 2013 | Panasonic TXL42S10B 42 in HDTVReady TV
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Need the remote se up coed for Panasonic tv.vcr combo model PV-2061. The nine 5 digit codes provided by Comcast do not work
Hello
Just try with these four digit codes
0374 0381
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your combo with its FRONT PANEL POWER SWITCH EACH TIME before trying an other code. OK.
Feb 17, 2011 | Panasonic PV-C2061 20 in. TV/VCR Combo
Panasonic codes tv
Hello
Three digit codes for Panasonic are
007 107 416 516 608 618 718 807 901
Four digit codes for Panasonic are
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
NB: Switch OFF and switch ON your device with its mains power ON/OFF switch at its front panel, before trying an other code.
OK.
Feb 11, 2011 | Televison & Video
Need the remote code for this model tv
Hello
Three digit universal remote code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit universal remote code for Panasonic are:-
Direct Code Entry
Note: Switch OFF and switch ON your TV with its front panel power control switch [Main power control] each time before proceeding for an other code.
OK.
Jan 20, 2011 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Tv won't turn on.
  • Try resetting the lamp timer
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
May 06, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Panasonic CT-36SX12 36" TV Logo
13 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
