Question about Maytag Refrigerators
I am trying to find the water filter on Maytag 25 MSSA refrigerator but I cannot find it. I need to change it so I need to know.Browsed on the internet but not much help.
I need to replace the water filter as it is not replaced from more than two years.The water filter was not found on the top right shelf corner where it is usually for most of the fridges.
SOURCE: filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Posted on Jan 08, 2008
SOURCE: water filter leaking
This happened to me and was the o-ring, the cup is sealed by the o-ring and in my case I did not realise it dopped off after I unscrewed. Either your o-ring is missing or needs replaced as it is worn out.
Posted on Aug 24, 2008
SOURCE: how to reset a maytag plus fridge
I have a Maytag Plus Refrigerator and the way to rest the water filter light is to simultaneosly hold down the "Light" and "Lock" pads until the "Change Filter" light blinks (approximately 3 seconds). This will reset the Change filter light for 12 months or for the number of gallon threshold for your filter.
Posted on Dec 15, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
arikrom
  • 528 Answers
SOURCE: Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Posted on Jan 02, 2010
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
Reset water filter light
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER
indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place. Let me know if you need the complete manual, Thanks, Sea Breeze
Apr 16, 2010 | Maytag MZD2766GES Side by Side...
Occasional water running out the side from under refrigerator
the ukf7003 filter is the correct one for your mod. the leak may be inside the freezer . the drain in back may be iced over and the defrost water is flowing out the door and not the drain/ but do ck the pan under neath and make sure it's nt cracked and is in place . .. place some towles around the base to locate where the water is commong from .. mm
Apr 15, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Need to know which water filter to get?
You can buy the filter on link below.
http://buyitnow64.stores.yahoo.net/maukpuiirewa.html
Please rate 4 thumbs for the free answer
Mar 14, 2010 | Maytag MSD2651 HE Side by Side...
NO manual for Fridge.
I can get the service manual for you. Here is what the manual tells you on page 101.
(Select Models)
FILTER
Thanks, Sea Breeze
Jan 18, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag msd2454gr refrigerator how turn filter light off after replacing filter?
FILTER
Nov 23, 2009 | Maytag MSD2454G Side by Side Refrigerator
Turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
How do I get the filter light off after changing the water filter?
PRESS THE LOCK AND LIGHT BUTTONS AT THE SAME TIME UNTIL LIGHTS BLINK.THEN IT WILL RESET FOR 12 MONTHS OR 44O GAL.HOPE THIS HELPS
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag lock and filter change
to reset the change filter light:
Press hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 sec.)
Dispenser lock:
to interrupt power to the water and ice dispenser so it cannot be used , press the lock pad 3 times within 10 seconds.
Jan 21, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
122 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
