Question about Philips Magnavox 51MP392H Rear Projection Television
TV Contrast Problem for Philips Magnavox 7P4830 W101
There's no contrast or hue setting for my tv. The picture color is out of focus
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiTV Contrast Problem for Philips Magnavox 7P4830 W1 - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
TV Contrast Problem for Philips Magnavox 7P4830 W1 - 578ba6c.jpgef="http://www.fixya.com/support/t1631691-red_aura_in_middle_55_phillips#" >Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 19, 2009
I have a sceptreflat screen hdtv that display a red picture Always
go into settings and check your hue settings.
This setting controls your color mix ratio
of primary colors red, blue and yellow.
Apr 22, 2017 | Televison & Video
Devant tv tech.model no.32DL410 power on but no display on the screen can you help me.???
Try goong to menu and check if brightness, color, sharpness, hue, contrast is set to 0. I have the same model, whenever I use USB in Source, those settings in menu automatically change. If thats the case, go ahead and change brightness to 50, contrast to 50, color to 50, sharpness to 2, hue to 50
Apr 04, 2017 | Televison & Video
Samsung tv calibration
You're asking about the picture settings to this TV; I assume, and posts this solution. Just set it to user mode; in terms of picture; set the Color to minimum (0); Contrast = 70 ~ 75%; Brightness to 30 ~ 40%. In this way, just set a picture in Black/White first. If you see that the contrast or brightness level should be adjusted to get a good B/W picture, do it according to your viewing taste. After set this, advance the color; and compare the skin tone of a news reader at the studio.
In most cases, this must be the perfect adjustment. If you wish to get more details to picture, advance the Sharpness control. Do not set it too more. Less than 30% will be sufficient. If the broadcasting system is NTSC, you have to adjust the Hue too.
Apr 18, 2014 | Televison & Video
The picture is so dark can't make out figures
It sounds that the back-light section has some fault with your TV. Otherwise, 30% brightness, 60 to 65% contrast, and 20 to 30% color settings should give you perfect picture.
Jun 06, 2013 | Digimate DGL20 Television
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Best picture settings for 19" philips tv
Brightness set at just half or a weasel hair more. The contrast at 75 to 80% Color at half or one weasel hair more, sharpness at 75%. Sharness is usually the background focus. Tint at half. Actually, I would have to say one of the best TV made is any of the 19" models. They have a rep for really lasting a long....also, the most optimum picture of all sizes made. A note here..sometimes the contrast is called picture, and if you have a cool,warm or normal setting...always go with normal.
Nov 10, 2009 | Philips 19PR19 19" TV
I need to know the picture settingd 60" magnavox.
Tries these settings the contrast full to the max setting.Set the backlight to the full max too.The rest sets it to the middle or to ur disire.
Because the contrast and backlight the most important in settings in colors adjusting.
Aug 30, 2009 | Philips Magnavox 51MP392H Rear Projection...
Need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Feb 14, 2009 | Philips 42PFL3603D 42 in. LCD TV
Phillips magnavox 50" projection TV shows a light picture
it sounds like the tv is going out. you might call a repairman before it does so you dont lose the tv.
Jan 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
498 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
