Sony motion eye webcam problem
I am unable to use my webcam to take pictures unless I am using Skype or MSN messenger (or similar). My laptop is a sony vaio vgn ns11j, and it is a motion eye webcam.
I have read that it should appear in My Computer under visual devices but it is not there. I have tried searching for all sorts of things on my computer and I seem to have no software relating to it. I have checked the drivers are installed and are on the most up to date ones.
How can I make it work?
THANK YOU! =)
VGNCR590 motion eye is not working, I am using Windows 7 Professional 32 bit
Visit the esupport webpage provided below:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E
Select Windows 7 Professional Operating System and re-install the WebCam Companion Software Utility and Magic-i Utility available for the computer. Also ensure to either run only the webcam companion software of any messenger software at a time.
If you are logged in to a messenger software such as Yahoo Messenger, Googletalk, Skype etc. Then, make sure to logout from the messenger and quit the application.
After that, start the Webcam companion software from all programs in start menu.
May 27, 2011 | Sony VAIO VGN-CR220E/P Notebook
I have a sony vaio vgn-fs790 laptop but cant seem to use the webcam i recently bought.my laptop cannot recognise this webcam and i think i dont have any webcam driver installed,please help out,this is the...
The built-in Motion Eye Camera is designed to add video functionality to many instant Messaging or video editing Software applications (such as Windows Messenger or MovieMaker). However the configuration process and support for how to set-up these individual applications is provided by the Software manufacturer, not Sony. Please contact your Yahoo Messenger support team for assistance on how to configure their Software.
TIP: Simply turning on your Computer activates that camera, so no specific
action is required to start the video services. Please note that only one
application can access the video signal at a time. If the signal is already
in use by one application, it will not be able to be detected by a second
Follow this procedure to take still image pictures with the integrated Sony Motion Eye camera.
1. On the taskbar, click Start and then click My Computer.
2. In the My Computer window, double-click the Sony Visual Communications icon.
3. In the Sony Visual Communications window, under Camera Tasks, click Take new picture.
Follow this procedure to capture video with the integrated Sony Motion Eye camera.
1. On the taskbar, click Start, point to All Programs, and then click Windows Movie Maker.
2. In the Windows Movie Maker window, on the left side under Capture Video, click Capture from video device.
Dec 12, 2010 | Sony VAIO VGN-FS790 Notebook
I just got a new sony vaio and Im not sure how to
You can either access the program that is installed for your camera or on say like an instant messenger like yahoo or msn, they will drop down menus that will automatically open your webcam when requested by you. Hope this helps
May 16, 2010 | Sony VAIO VGN-CS215J/W Notebook
I cannot see my picture.
Can you please describe your issue more clearly?
If you are unable to see the picture on a messenger software like yahoo,msn or skype etc. then please reinstall the messenger software and also your webcam drivers/software this will fix the issue.
Let me know if you need any more help.
Thank you for using fixya,
Dec 13, 2009 | Computers & Internet
Argh!!!
The motion eye is the webcam for your laptop. Look for any webcam program on the laptop and that will control the motion eye. In fact you can install yahoo messenger or any other like that and use it.
Look in your start menu and you will find one to use.
Aug 22, 2009 | Sony VAIO VGN-FE880E/H Notebook
My webcam does not work on msn
first you need to know that if you used xp ...and upgraded to vista ...you need to find a compatible driver for your web cam too ...if your web cam used to work just fine on vista ...and its just the msn issue ...just reinstall the latest MSN messenger and it should be enough ...also verify the proxy servers on the messenger preferences..and set 'em to fit the kinda conexion you use...
but I suspect a problem with the program settings ...so the easy way is just to install the latest messenger(MSN) available for vista ...and it will be ok
May 17, 2009 | Logitech QuickCam Pro 5000 Webcam
Dell webcam manager working with msn messenger?
if you have the webcam center opened along with with msn then it wont work on either one of them.
you can try these steps tp check if it works for you or not.
1)look for the web cam center system tray icon and right click on it if its there and select exit
and as u said u cant see you self in web cam console --- in webcam console you can only see your self under the doodling tab and only of your webcam is working at that i.e
either you have the webcam center opened or any other messenger or software which turns on your cam then only ull be able to view your cam in webcam console alongside.
Apr 28, 2009 | Dell XPS M1530 Laptop
Acer crystal eye webcam (aspire7720-6155)
First is a good sign that if you click the Icon form the webcam software, and you see your picture. This indicates that the webcam drivers were installed correctly.
You will need a software that support the webcam to be able to use it. You can Try Skype (http://www.skype.com/), or MSN Messenger (http://im.live.com/).
Those programs will detect your webcam and will enable video chat, that way you can use your cam to communicate with others.
Hope this helps..
May 01, 2008 | Acer Aspire 5610-4648 Notebook
Acer Crystal Eye Webcam and MSN Messenger
hi,the acer crystal eye has issues with mcafee site adviser either delete it as i did or configure it.search mcafeemessenger click on microsoft live messenger 2009 (v140) conference link to the appr opiate page hope this is helpful.
Mar 19, 2008 | Acer Aspire 4315 Notebook
Computers & Internet Logo
471 people viewed this question
David Payne
David Payne
