Question about Garden
Bolens 2 cycle tiller will not start
Put in new plug, mixed new fuel. It is getting a spark and there is fuel going to carb. Will fire with primer but will not run. Have messed with idle speed screw. Could this have anything to do with not starting problem?
If so what is the best way to reset the idles screw.
    Sniper:
  • 57 Answers
Improper adjustment is a possible problem. However could also be trash in carburetor. Adjustments can be tricky. Recommend a tech.
Posted on May 18, 2009
Powerhouse tiller viper 2 cycle 43cc engine replaced primer bulb now won't start.
overhaul the carby with new diaphragms or new carby
( almost as cheap from e-bay as a overhaul kit from the mower shop)
if no carby bowl , the diaphragms that pump the fuel will be hard and nor seal properly on the seats
Apr 25, 2017 | Garden
Im the girl asking about my fuel line for my tiller bolens 31cc tiller BL410 I put newlines &new bulb on! Want stay running, changed lines around,cleaned screen but want stay running but few seconds
If it is a 2 cycle motor, check the spark arrest or screen in the muffler. It is a fine screen and the oil in the exhaust leaves a carbon buildup that will plug up the screen. It can be cleaned with a brass wire brush or carb cleaner.
Mar 30, 2017 | Garden
Mantis tiller problems
First, I would mix up a batch of fresh fuel. Stale fuel will prevent a 2-cycle engine from starting. If it still will not start, you need to determine if the engine is getting fuel and spark. Remove the spark plug, re-hook it to the spark plug wire, ground the plug against a metal part of the head near the spark plug hole, and pull the rope to see if the spark plug is producing spark. You may have to do this out of direct sunlight to get a true reading. If you have spark, spray some starting fluid into the spark plug hole, reinsert the plug and try to start it again. If it starts then you have a fuel problem which could be a bad primer bulb or a carburetor problem. If it will not start then you may have low compression which is an expensive repair. Try these things and post back.
Aug 14, 2014 | Mantis 2-Cycle Tiller
Tiller will not start
Check first whether you are actually getting a spark. Remove the plug, re-attach the spark lead and place the body of the plug in contact with the engine block. If the engine has a cowling which makes this difficult, you can use a socket from a socket wrench set or something similar to bridge the gap. Alternatively get an assistant to hold the plug against the engine with a plastic clothes peg. Pull the cord and check the spark is ok. It may be easier to see it in the shade or indoors (Don't run an engine too long indoors).
Problems with 2-cycle engines are often due to fuel flow issues in the carburetor. If the engine has a primer, make sure it is sucking up fuel. Look inside the tank and check that gas runs out of the return line when the button is pressed (the line without the filter).
Clogged jets can cause problems. These can be cleaned with a carburetor cleaning aerosol.
The valve in the gas tank cap can become clogged with particles of dirt. Check this is clear.
For a pictorial guide to cleaning a carburetor on a 2-cycle engine (used on string trimmers, chain saws, hedge trimmers and some lawn mowers), see my guide at the link below
String Trimmer Won Work 2 Stroke Engine and Carburetor Troubleshooting
May 16, 2014 | Mantis 2-Cycle Tiller
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
If you lent your tiller to your "know it all"
While having your brother buy you a new tiller sounds good, it just might not be practical or posible. So drain the fuel from the tank, fuel lines and the carb., clean the spark plug and replace fuel filter if installed. Put the proper gas in and start it, should be good or clear up pretty quick. Hopefully it did not run with the wrong fuel for too long where the spark arrestor in the muffler would get clogged up.
Good luck.
If really helpful, please rate.
Jul 13, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Will not get to working speed
RECOMENDATIONS:
-Drain all fuel from the fuel tank.
-Remove and REPLACE with a NEW spark plug.
-Remove and RELPACE with a NEW Air filter.
-With spark plug and air filter removed and fuel drained pull the starting cord many times 12 or so to ensure there is no fuel in the chamber and also check for a spark at the plug.
-RE-MIX WITH NEW FUEL your 2 cycle oil to the correct ratio in a clean fuel can. it is OK to dump some in the fuel tank slosh around and dump out in an approved container for disposal.
-Hold off on putting back on the air filter until you have had it running
Hope this tip helps.
R/David
Jan 19, 2010 | Mantis 2-Cycle Tiller
Matie 2 cycle will not run when throttle is ful on.
Make sure all of your bolts are tight, especially the ones on the carb. If so you will need to clean the carb.
Mar 27, 2009 | Mantis 2-Cycle Tiller
My tiller won't stay running
this is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
Oct 06, 2008 | Mantis 2-Cycle Tiller
Garden Logo
482 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
