Question about Dell AA23300 550W Power Supply (X0551) Power Supply
Can you supply pinout for Dell Ac255ad-00 Power Supply?
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Power supply Dell NPS-200PB-73M
You can buy it here.
Posted on Mar 01, 2008
gripfitter
  • 557 Answers
SOURCE: Can you supply pinout for Dell AA23300 Power Supply ?
On the main plug there is a single green wire. Jumper the green wire to any black groung wire in the plug and the fan will start and you will have output.
Posted on Dec 20, 2009
SOURCE: Pinout for dell power supply with model number Ep071298
There are no wires, it's a big hot-swap plug.
Posted on Mar 14, 2012
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Pin out for a dell PS-5201-8D2 power supply
Use caution, some older Dell machines used a non standard, proprietary pin-out on the 20 pin connector ALso the 6 pin is suspect. If you connect a regular ATX PSU, you will fry the MoBo. Look here
DELL ATX motherboard Power Supply pinout
Jan 23, 2013 | Dell (PS-5201-8D2) (PS52018D2) 200-Watt...
Will a NVIDIA GeForce gt 610 graphics processor work on a Dell Dimension 2400 PC Desktop
YES, Zian it will work....BUT,....................
1) It is a PCI graphics card, and uses a PCI expansion slot.
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2898922&CatId=319
The Dell Dimension 2400 Desktop PC's motherboard, has three long white PCI slots,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105465
http://www.ebay.com/itm/Dell-Dimension-2400-Desktop-Motherboard-System-Main-Board-F5949-K5148-G1548-/190750417467?pt=Motherboards&hash=item2c699c623b
http://en.wikipedia.org/wiki/Conventional_PCI
If one of those long white PCI slots is open, you can use a PCI graphics card.
Concerned that the graphics card uses DDR3 graphics memory, and your computer only uses DDR Sdram ram memory?
Don't be.
The graphics card has it's own processor (Graphics Processing Unit), and graphics memory.
It runs independent of the system resources; the Processor and Ram Memory.
http://en.wikipedia.org/wiki/GPU
The concern is the Power Supply.
Original power supply's maximum rated Wattage is either 200 Watts, or 250 Watts.
The above graphics card requires a minimum system requirement/power supply requirement; of 300 Watts.
I would recommend replacing the Power Supply.
(Especially with it's age, if it is still the same one)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078
ONE thing though..............
Watch the 20-pin ATX main power cable connector, and the wires in it. Be sure they are in the standard place setup.
Check the pinout, and color code of the wires,
1) Dell Dimension 2400 desktop computer, 20-pin ATX main power cable connector pinout,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105612
2) STANDARD 20-pin ATX main cable connector pinout, and color code of wires; as set by JEDEC,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[Be aware that the ATX main power cable, and connector, you get with a new power supply; such as the above, will have a 20 =4-pin ATX main power cable connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
Use the 20-pin connector, tie the 4-pin power cable up out of the way]
For a time period Dell was making the motherboard's main power cable connector - Proprietary.
Meaning they has that motherboard connector wire pinout changed.
Colors of wires were in a different place, than the standard setup by JEDEC.
Orange wires are 3.3 Volts (DC)
Red wires are 5 Volts (DC)
Yellow wires are 12 Volts (DC)
Black wires are Ground wires.
Guess what happens if a 12 Volt Yellow wire, is plugged into where a Black Ground wire is supposed to be?
ZZZZZZzzzzt! Motherboard fries, processor fries, ram memory fries, and graphics card. (If used)
Check the color code of the wires, in the 20-pin ATX main power cable's CONNECTOR, for the Dimension 2400's power supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 14, 2012 | Dell Dimension 2400 PC Desktop
I Like to use the Dell PowerEdge 2600 Mfr P/N 7000679-0000 (supplier ATSN) power supply stand alone. Could you please provide me the pin-assignments on the connector?, for 12V Your help is highly...
The fact that it is a dell IS relevant because dell is always doing custom plugs and connectors and form factors. It has no ATX plug. This a server power supply and has no green wire. I would like to use this as a stand alone psu too because it delivers 60 amps of 12v.7_22_2012_8_22_34_pm.jpg
have fun.
Mar 14, 2011 | Dell NPS730AB 730Watt Power Supply
Nov 03, 2009 | Dell AA23300 550W Power Supply (X0551)...
I just need a schematic for the ATXpower250 power supply.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm#atx-psu-pinouts
Jan 20, 2009 | StarTech.com (ATXPOWER250) 250-Watt Power...
Dead Dell
It is likely the power supply has suffered damage, or has just plain failed. Dell did have problems with certain power supplies in models such as the GX270, probably others too.
Anyway, if you have a voltmeter, you can check for the presence of voltages. Modern computer power supplies have a standby and main sections. I'd guess the standby portion is dead, and if so, your computer won't turn on at all. Here is a site listing the pinout & voltage spec for a typical ATX power supply: http://pinouts.ru/Power/atxpower_pinout.shtml
Note the standby line- again, this voltage will be present anytime the computer is plugged in. The main section of the power supply comes on when the power button is pressed.
If you tech savvy, you could try repairing the power supply if not toasted severely. Otherwise, a standard universal replacement might fit the bill, or just call Dell for an exact unit.
Jun 13, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 9100 will not power up
Most likely the power supply have failed. Although the system is getting some power to the Motherboard (Flea power indication on motherboard) there are at least 5 different voltages the power supply provides for the system. Losing any one can cause a no power situation like you describe.
A standard ATX power supply should resolve (It is the 1st item I'd replace, both because it is the 1st point of failure and the cheapest to replace)
Here is one ATX power supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182030
Jun 13, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
159 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
