Question about AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner
Tiger Shark pool cleaner does not clean the whole pool
Hi I have a Tiger Shark for an in ground residential pool Model Number: 9950. The first year it worked fine then the second year it would not climb the walls so a new motor was put in. It now climbs the wall but it does not cover the whole pool. No matter where I start the cleaner, shallow or deep end it always ends up going back and forth over the same swath in the deep end and does not clean the shallow end.
I am not keen on going back to the dealer because the cost of repair is too high. For instance the new motor cost almost as much as a new device.
5 Suggested Answers
SOURCE: tiger shark just doesnt clean very well
I the filter is not very clean the pump will not push hard enough to hold the tracks onto the walls. Try running without filter in a very clean pool for a few minutes to see if it solves the climb walls replace the filter and clean the unit
Posted on Jun 21, 2009
  • 83 Answers
SOURCE: i got a legend platinum poll cleaner this week and
The first thing I would check is the swivels in the hose line. Make sure all of them spin, it not then replace that swivel. You may also want to check the length of the hose, if it was not adjusted to the proper length, this could be the issue also.
Another place to check is other reurn lines. If your pool has more than one return line, check to see if that line is shooting water across the top of the pool, if so, you may want to adjust the flow downward at on angle. The returning water may be stopping the hose and the unit from going to the shallow end.
Posted on Jul 01, 2009
thepatioman
  • 52 Answers
SOURCE: My tiger shark pool cleaner spends a lot of time
the tiger shark is designed to climb but you can adjust the weights to keep it down. check out http://www.aquavacsystems.com/Weights-and-Floats_ep_31-1.html
for more info and specs of your unit. good luck
The Pool Tech
Posted on Jul 14, 2010
  • 3 Answers
SOURCE: Aquavac Tiger shark won't operate
The power supply powers on even when it doesn't output any voltage, so it's kind of misleading. You should have the power supply checked or you can do it yourself if you have a multi-meter, by measuring the output and making sure there is 24V.
Posted on Jul 17, 2010
I have a tiger shark one and half years old. it turns on, can hear the motor going and it will move and clean regularily anywhere from 20 sec to 5 minutes. but then will get stuck in one spot. the motor...
The motor pack is having trouble and will need to be replaced (most likely). For help finding a service center that can perform the inspection and repairs check Hayward's site at http://www.haywardnet.com/locator/ and fill in the information requested. Be sure to select product repair or service and robotic cleaners to limit the response to those able to fix these cleaners. We are in S.E. Michigan and are one of the centers for Tiger Shark cleaners.
John
Oct 10, 2010 | Aqua Vac Tiger Shark
My tiger shark pool cleaner will run for about 30 sec. then shut off. how can i fix this problem?
The pool cleaners impeller may be clogged or jammed with debris. Check and clean if necessary. The brush rollers or drive tracks could also be stuck. Check for debris and remove. It is most likely one of these problems if it is shutting off after only seconds of running. If these don't seem to be the problem, I would check your power source.
Aug 18, 2010 | Aqua Vac Tiger Shark
Jul 17, 2010 | AquaVac Tigershark Plus Robotic Automatic...
My tiger shark pool cleaner spends a lot of time at the top of the water line. How can I adjust it so it does not climb so far?
The Pool Tech
Jul 02, 2010 | Aqua Vac Tiger Shark
How can I keep my Tiger Shark from sticking to the main drains in my inground pool.
Decrease suction on main drain and increase suction to cleaner.
Jan 15, 2010 | Aqua Vac Tiger Shark
Tiger shark will not move
The motor that drives it forward and back is seperate from the fan and is defective unless your stuck on the main drain the motor unit needs replacing.
Mar 14, 2009 | AquaVac Tigershark 2 Commercial Vac with...
AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner Logo
319 people viewed this question
Top AquaVac Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Steve Slater
lioneltrain5
Level 1 Expert
Are you an AquaVac Pool and Spa Expert? Answer questions, earn points and help others
