Question about GE Energy Star WCVH6260F Front Load Washer
Violent Shaking/Pounding/Dancing During Spin-Cycle
I just purchased a brand new General Electric Front Loading Washer (model # WBVH6240FWW) from Sam's Club a few days ago. I installed it, attached the hoses, drainage, and everything then put a very light load of white towels in to test it out. It ran for the first 15-20-ish minutes just fine with no abnormal noise or movement, but then it all went downhill at the spin cycle.
After draining, it hit the spin cycle and began violently shaking and banging back and forth resulting in steady movement across the floor doing damage to the linoleum. I shut it off to check the balance and found it was leaning because the front right leg was a little shorter than the other three. I tipped it up and adjusted that leg to the same height of the others three, and "shook" it back and forth to check for movement. Nothing. I sat on top of it and yanked it with my full weight a little just to be certain it was solidly on the floor. Still nothing. Satisfied, I turned it back to the "Drain & Spin" setting and waited for the spin cycle to kick back on, and the violent shaking/banging continued like before.
I'm at a loss as to what is wrong. I can't tell that it is unleveled in any way, and it literally just came out of the box from the store with a matching dryer (which works perfectly btw). The trip inside the house was very soft and uneventful, so I'm sure no damage was done in transit.
Can anyone please help me out?
  • 3 more comments
  • Anonymous Nov 07, 2007
    I'm having this problem and read that a thick rubber mat placed under the machine will absorb much of the vibration. Also, the problem may lie in a sagging or weak floor joist. If you own an older home you may want to shim up the floor and brace between floor joists to make the floor more rigid. I am currently in the process of inspecting and correcting weaknesses in a 60 year old home floor structure and hope this cures the shaking machine problem.
  • ckatz Nov 26, 2007
    We have a new similar model (6600). It also shakes violently (you can see the drum pounding the side and forcing it out),. It sits on a pedestal, which may magnify the prob, but it is the GE pedastal made for this machine. The wood floor is somewhat unlevel, but solid. The machine is sitting perfectly level in all directions. It replaces a Maytag Neptune which sat in the same spot for years and NEVER shook.
    To date, the GE authorized repairman has replaced every moving part, including the drum amd flywheel, but not the shocks. He ordered new shocks today. Fingers crossed.
    I have to believe that the problem is systemic, possibly a design problem, since replacing the drum, etc. helped somewhat. It seems that my only remaining option, if new shocks don't help, will be to go to war with GE. I fear that it may require me filing a claim in small claims court.
  • Frank M Jan 07, 2008
    I have had the same problem since I got the machine. I had a repairman look at it and he told me that the machine was fine and I should put something under the legs to prevent it from shifting and shaking. Any suggestions?
  • Kfish05 Apr 06, 2008
    My husband and I had the same problem with our GE Front Load Wash Machine. We had the violent shaking/pounding/moving problems and our clothes were still saturated with water when the cycle was complete. The spin cycle is when the problems take place.
    Four service calls later our machine was replaced.
    The first machine was serviced the balancing bricks were replaced and the spin cycle speed was adjusted to a higher speed. The feet of the machine were adjusted. This problem still continued. One of the repairman knew of the problem and stated the balancing bricks were the problem. He told us GE had problems with defective bricks.
    Now our second GE Front Loader is doing the exact same thing with one more added problem-the fabric softener location has water in it when the machine cycle is over.
    My floor and dryer are taking a beating due to the wash machine hitting the dryer and rubbing the linoleum floor.
    We have an appointment with GE next week.
    Hopeful that GE will come through for all of us!
  • jmwright Dec 14, 2008
    Same basic problem, since the machine was new. Machine [installed on level concrete] sometimes works fine, but often can't seem to balance a load, running for hours and ending with wet clothes. Had 3 repairmen out. The first one replaced the control board, but that didn't help. Others checked the pump, etc, and report the machine to be OK. They all have said that running with a large load helps, but that's an absurd solution.
    This seems to be a design problem, since other makes don;t seem to have the load distribution problem.
    My next step is to demand GE replace it, or small claims court.
Problem solved
Remember that GE had replaced every thing including drum, balance wheel. pulleys, etc over 4 service calls totaling probably 2 hours. No help what so ever.
I asked the repairman if they had replaced the shocks. He said that they had removed them and all were working properly. After I insisted that the shocks also be replaced, the repairman, with rolled eyes, very reluctantly agreed to order 4 new shocks. (these are cheap plastic friction shocks).
When he came to install them, I watched and grabbed the old ones. I noticed that one was slightly less resistant to pressure than the others. He laughed and said that couldn't possibly make a difference.
After reassembly with new shocks, the violent shaking stopped and has never returned.
Posted on Apr 07, 2008
I had the same problem and the repairman told me that the shipping brace on the drum was not remove and it has been working fine
Your problem is the same as mine -- the washer drum shaft was bent by mishandling in shipping (between the manufacturer and the distributer.  This is a warranty issue.  Call GE service.
Posted on Oct 28, 2007
  • Charles Eicke
    Charles Eicke Aug 15, 2011
    i had the same problem, i took the top off and let it run to see what it was.. It was the rear counter balance, ( looks like a piece of cement) the bolts had loosen up or were never really tight.. ps. dont over tighten just make the snug.
    it fixed my problem
Take the shipping bolts out from the back
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
Jul 7, 2013 - Uploaded by
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Drum knock when spin cycle
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool design 2000 is imbalanced eery load - moves around violently, makes pounding noises.
Thanks for choosing FixYa and welcome. You need to check the suspension of the washer and make sure everything is intact. Now, if the washer is thumping during spinning, this is probably the motor drive or the spin bearing. This would cause a lot of noise. Your washer will act up if it is not balanced right. Check the floor and make sure it is level. If that checks out, look into the motor drive and bearings. The motor drive controls the spinning.
Apr 28, 2011 | Whirlpool Washing Machines
Violent spin cycle on the Frigidare front-loading washer
I assume you bought it new, so on that basis, did you remove the transit packing materials inside the machine ?
Front loading washing machine normal design is for the drum assembly to be supported by two or more springs at the top, and two dampers at the bottom. This allows the drum to move in a controlled fashion and also minimises vibration, particularly during spinning.
When the machines are shipped from the factory, transit packaging is put inside the machine to ensure that any shocks to the machine during transit dont damage the springs or dampers. This must be removed before use otherwise you get pretty much the symptoms you describe.
The manual that cam with it will show you how to remove the transit packaging. In such a short time I suspect you wont have suffered any damage, but take the transit packaging out as soon as possible.
Nov 04, 2009 | Frigidaire ATF6000ES Front Load Washer
GE front loading washer - WBVH6240FWW
Most modern front loading machines have a ESTIMATED time display, this time can change based on the inputs from different sensors and water temperature. So this should be normal.
Jan 16, 2008 | Washing Machines
Washer was jumping and dancing when it got to spin cycle
The only thing to check is to see that some struts behind is taken off. This is inserted to prevent the drum from banging around during transit; refer to your manual. Important.
Jan 12, 2008 | LG WM2487H Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
7,108 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
