Question about Michley Lil Sew Mechanical Sewing Machine
Top thread is not picking up
Top thread is not pulling bottom thread through fabric
My bottom tention of Bernina Deco 340 is to loose. How to I correct is. The top treat shows to much at the bottom
Um, the top thread is showing on the bottom of the fabric? The top tension is too loose. The two threads create a tension battle, one pulling against the other. To pull the bobbin thread up, tighten the top tension. The tension is accurate when the two threads meet "in the middle" of the fabric. On thinner fabric, you might see a tiny spot of bobbin thread on the top and a tiny spot of top thread on the bottom.
Aug 24, 2017 | Bernina Sewing Machines
Thread bunching up on bottom of fabric
Remove the top thread from your machine (NOTE: ALWAYS clip the thread next to the spool, lift the presser foot, and gently pull the top thread down from top to bottom!!! This helps reduce the chances of breaking something by pulling the thread upwards!)
ALWAYS RAISE the presser foot and rethread the top thread from beginning. Verify the thread path is correct and start out with the thread tension set at the midway point (and then tweak the top thread tension through testing).
FWIW, if the thread problem appears under the fabric, it is generally a top thread issue. If the thread problem appears on the top of the fabric, it is generally a bobbin thread issue.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
CURED Sewing Thread Nests on the bottom
Jul 04, 2017 | Sewing Machines
Adjust tension
The tension of the top thread and bobbin thread are in a "tug of war". If the top is "winning" or too high then the bottom thread will be showing on the top of the fabric. If the top is "loosing" or too loose then the top thread will be pulled through the fabric and show a lot on the bottom. They must be evened out so the "tug of war" is even so the knot is in the middle of the fabric.
START WITH BOBBIN FIRST: Remove bobbin and bob from finger. When you have it adjusted right then the bobbin will extend one inch when you bob it. If you can't bob your bobbin you will have to make an approximate and replace. You may have to do this a couple times to get it right.
WHEN IT'S RIGHT: The bobbin and top tension are equal without being too much pull on both that causes the fabric to pull together.
Jan 31, 2015 | Sewing Machines
How do I fix the bottom bobbin thread
THE BOTTOM AND TOP THREADS ARE IN A TUG OF WAR. WHEN THE TOP IS TOO LOOSE THE BOBBIN WILL BE PULLING HARDER THAN THE TOP THREAD SO A GREAT DEAL MORE THREAD WILL END UP ON THE BOTTOM. TO CORRECT THIS YOU INCREASE THE TOP THREAD TENSION. IF THE TOP THREAD IS PULLING HARDER THAN THE BOTTOM THEN A GREAT DEAL MORE BOBBIN THREAD WILL END UP ON THE TOP. TO CORRECT THIS YOU WOULD LOWER THE TENSION ON TOP.
Dec 12, 2014 | Sewing Machines
I have a singer 7258 that I can not get the tension to loosen up on. The top stitch is straight across and adjusting dial doesn't help.
Hello
Adjust the tension
Load your sewing machine with one color on top, threaded through the needle. Load the second color thread into the bobbin and thread.
Fold the scrap fabric in half, and sew a straight stitch at least 2 inches long. Look closely at the seam. If you see loops of the bottom color thread on top of the fabric, proceed to Step 3. If you see loops of the top color thread on the bottom of the fabric, proceed to step 4.
Loosen the top tension. Since the top tension is so tight, it is pulling the bottom thread up through the fabric. Loosen the top tension by turning the numbered knob on the front of the sewing machine counterclockwise by one number.
Tighten the top tension. Since the top tension is too loose, the bottom thread is pulling the top thread down through the fabric. Tighten the top tension by turning the numbered knob on the front of the sewing machine clockwise by one number.
Sew a straight stitch 3 inches in length. Check the stitching. It is perfect if the threads meet in the middle, and you can only see the top thread on top and the bottom thread on bottom. If it still needs adjusting, go back to step 2 to repeat the needed steps.
Using two different colored threads makes it easier for you to see which thread is being pulled.
Always use proper precautions when working with electrical machines.
Aug 01, 2011 | Singer Sewing Machines
Pulls bottom colored thread to top...how do I ajust New Home 8000 trying to zig zag and bottom thread pulls color to top....
The bottom thread is the bobbin thread and it is suppose the pull the top thread slightly to the bottom/center of the layers of fabric.
Try a lower tension setting and a tear-away stabilizer or sheet of printer paper under the fabric to see if this will help hold the top thread down into the fabric.
Mar 27, 2010 | Sewing Machines
Singer 301a...sews on top of fabric nicely...bottom is just loose loops of thread...it's like the bobbin is not sewing...I put 2 different colors in to see...top is perfect...on bottom of fabric I see the...
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Jan 25, 2010 | Singer Sewing Machines
My sewing machine will not pick up the bobbin thread. It sounds normal and pulls the fabric through, but the threads do not intertwine. I had been having problems with the bottom thread clogging and...
when the needle pulls the fabric into the feed dog you dont have enough fabric behund the neelde when you srart, and the fabric gets caught in the feed and the bobbin case underneath clean it out anf change the needle they often get bent after they get tangled in the thread and fabric
Dec 10, 2009 | Bernina Sewing Machines
BOTTOM STITCH IS ALWAYS LOOSE
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Mar 13, 2008 | Sewing Machines
Michley Lil Sew Mechanical Sewing Machine Logo
Top Michley Sewing Machines Experts
erebooni
Level 1 Expert
Robin Hill
Robin Hill
Are you a Michley Sewing Machine Expert? Answer questions, earn points and help others
